2016 Build Help
JerryRig
I am new to PC building and need help deciding what to get for a good PC around 2000-2500CDN$ that will last me around 2-3 years.
I am just playing in 1080p right now, but I would like to be able to play 4k.
I dont need peripherals or any of that.
I want to be gaming on max settings in all the new content for 2016 and 2017
What is your build for? Work, 3D, editing, rendering, gaming?
PC only or with Monitor, mice, keyboard, etc.
uses???
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
I just updated it look above.
CPU: i7-4790k
CPU Cooler: Cooler Master Evo 212
Motherbaord: Z97 Chipset
Memory: 2x8GB (16GB) 2400 MHz
GPU: GTX 980 Ti 6 GB
PSU: 850 watts PSU
Case: ATX Mid Tower Case
Storage: 120 or 240GB SSD (With OS on it)
Storage: 1 or 2TB HDD
OS: Windows 10
1k watts is a little bit too much even if you plan on OC'ing, a 750W or a 850W would be better, hell even a 650W would be
@JerryRig you might want to go with a 390/390x as they are more cost-effective and still have very good performance at 1440p/4k
This will handle 4k very well, but get some extra case fans to keep the airflow going in the case because those GPUs can get quite hot without it
PCPartPicker part list: http://ca.pcpartpicker.com/p/xkbfqs
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor  ($405.00 @ Canada Computers)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($26.95 @ Vuugo)
Motherboard: MSI Z97-GAMING 5 ATX LGA1150 Motherboard  ($154.98 @ NCIX)
Memory: G.Skill Ripjaws X Series 16GB (2 x 8GB) DDR3-1866 Memory  ($88.98 @ Newegg Canada)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($105.29 @ Vuugo)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($86.29 @ Vuugo)
Video Card: MSI Radeon R9 390 8GB Video Card (2-Way CrossFire)  ($435.00 @ Canada Computers)
Case: Phanteks Enthoo Pro ATX Full Tower Case  ($127.99 @ Amazon Canada)
Power Supply: EVGA SuperNOVA 1000G2 1000W 80+ Gold Certified Fully-Modular ATX Power Supply  ($228.50 @ Vuugo)
Total: $2093.98
Generated by PCPartPicker 2016-01-01 22:06 EST-0500
I already have an SSD that I am using from my current PC
