hi, i just built a computer not long ago however it seems to be booting very fast, too fast. I know i have an ssd and that boot it literally takes a second to load, and my friend said it was on fast boot mode. Is this true? Also if so, how do i switch of? Another thing is that i think my BIOS is in easy mode, how do i sort that out?
thanks in advance.
https://linustechtips.com/topic/517505-i-think-my-pc-is-in-fastboot-mode/
thanks in advance.
why would you want it to boot slower?
thanks in advance.
Why would you want to disable fast boot?
CPU: i5 6600k OCed to 4.5Ghz @ 1.35v, GPU: R9 390 Nitro, Motherboard: Asus z170-A, CPU Cooler: H100i GTX, RAM: HyperX 2x8 16gb DDR4, PSU: Seasonic x650, Storage: 850 EVO 500gb, WD 1tb blue, Case: H440 White/Black
thanks in advance.
Too fast? Why do you want it slower?
Other systems I've built:
and what about the easy mode when i launch the BIOS?
In you motherboard manual it should tell you how to access advanced mode.
Fast boot as BIOS option isn't enabled by default. So if you want to disable it, easiest way is to reset BIOS settings. This can be done either by pressing Reset CMOS button/switch on mobo (refer to manual) or removing BIOS battery for 15s while power cord is off.
I haven't heard of any Easy Mode. UEFI interface can seem like that but all options are still there. You just need to go into different tabs to find them. Like @Sportiva said, check manual for where to each tab leads.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
My asus z97-a has an easy mode. It's basic. There should be an option along the top for advanced mode.
But yeah easy mode uefi bios modes do exist
My rig:
CPU: i5 4690k 24/7 @4.4ghz (1.165v) Max 4.7ghz (1.325v) COOLER: NZXT Kraken X61 MOBO: Asus Z97-A   RAM: 16GB Crucial Ballistix Tactical   GPU: EVGA GTX 970 SSC   PSU: EVGA GS 650W   CASE: NZXT Phantom 530 HDD: WD Caviar Blue 1TB + WD Black 2TB
