Do I need a network card?
Kaspertechgeek
Go to solution Solved by Altecice,
If you're already hardwired in, then no, it won't improve speeds by anything significant.
The benefits would likely be reliability (if it's a good card) and more features.
^ This, the inbuilt Intel LAN's are actually very good at what they do. They even perform better than the Killer NIC's that are "made for gaming!!!"
What are the advantages of having a network card?
I'm using an ASUS M5A99FX PRO R2.0 motherboard. When I do an internet test I get roughly 45 mb/s of download speed trough my provider.
Will a network card help me take advantage of this speed?
AMD FX8350 Black OC 4.5ghz--NZXT Kraken X31--ASUS M5A99FX PRO R2.0--MSI R9 380 4G--Corsair RM750--Corsair 16GB Vengeance
Logitech G300--Roccat ISKU FX--Logitech Z623--HyperX Cloud II
Intel I9-9900k (5Ghz) Asus ROG Maximus XI Formula | Corsair Vengeance 16GB DDR4-4133mhz | ASUS ROG Strix 2080Ti | EVGA Supernova G2 1050w 80+Gold | Samsung 950 Pro M.2 (512GB) + (1TB) | Full EK custom water loop |IN-WIN S-Frame (No. 263/500)
I have a 990fx build though. But it won't be much difference compared to an Intel because my other build is an intel I7 z77 build and it's about the same speeds.
