Zipties color and length option
Mr Fister
Hey i want to buy Zipties for my cable managment.
and i want you guys to tell me which length and color should i choose.
http://www.ebay.com/itm/4-X-150-200-250-300mm-Nylon-Plastic-Cable-Wire-Zip-Ties-Cord-Wrap-Multi-Colour-/291602733733?var=&hash=item43e4e09aa5:m:mb3HDy25aJNUsedudL6I-JQ
NOTE: AMD GPU and CM HAF 932 Case
Gaming Laptop: Dell G5 5587
get em all then never worry about zip ties again.
Bleigh!  Ever hear of AC series?
Just choose whatever fits your setup with color. - Buying a pack with more colors is good if there are all the colors included that you need. Otherwise - buy them seperately
Black goes with everything - no different with zipties :)
White is also good pretty much for most things
You can mix things up more if you want something fancy but Black/White + your color of choice should be good for most part.
Length doesn't matter because you will cut them off after finished :)
CPU: Pentium G3258 @ 3.2ghz    Motherboard: Gigabyte Z97X-SLI   RAM: 1x 8GB HyperX Fury    GPU: GTS450
HDD: 250GB WD    SSD: 240GB SanDisk Now300   PSU: Old 400W Thing   Monitor: Old Samsung LCD 1680x1050
Keyboard: Perixx PX-1100   Mouse: Perixx MX3000-R   HeadphonesAudioTechnica ATH-M50X BL   Mic: Auna MIC-900BG
Basically any colour will do (as long as it fits with your colour scheme).  As to length use the shortest you can get away with as the cutoff portion is just wasted.  And thickness depends on how 'strong' you need the ties to be ( so one thin wire 'tied' to the case a 1mm tie is adequate, however a full bundle of six sets of fan wires may need a six mm one).  Basically go for a set of multi width, multi length, multicolour and use whatever fits/suits best.
E.G.
http://www.amazon.co.uk/gp/product/B00WK1EASA?keywords=zip%20tie%20sets&qid=1451498083&ref_=sr_1_1&sr=8-1
UK specific, but I am sure there is similar near you .
 Two motoes to live by   "Sometimes there are no shortcuts"
                                           "This too shall pass"
 Mmm four sizes X six colours is 24 bundles. At 100 ties a bundle wonder how long you would take to get through 2400 cable ties. ;)
Exactly ;)
