Backplate for a reference 290x with Raijintek Morpheus
Dunkl
Hello , I have recently changed the cooler of my R9 290x to a Raijintek Morpheus and I wanted to know if there is any Backplate that I could mount on my card without having to mod it.
Thanks in advance!
something like this:
or you could just try to look for a reference card backplate, maybe some from EKW suites you?
CPU: Intel i7 5820K @ 4.20 GHz | MotherboardMSI X99S SLI PLUS | RAM: Corsair LPX 16GB DDR4 @ 2666MHz | GPU: Sapphire R9 Fury (x2 CrossFire)
Storage: Samsung 950Pro 512GB // OCZ Vector150 240GB // Seagate 1TB | PSU: Seasonic 1050 Snow Silent | Case: NZXT H440 | Cooling: Nepton 240M
FireStrike // Extreme // Ultra // 8K // 16K
EK makes backplates for the reference PCB but they only fit if you use the EK waterblock as well.
that's quite sad
I kinda get the feeling that the Raijintek Morpheus is a little bit to heavy for the PCB because the PCB is slightly bending so I really need to find something soon :/
