help me with drive partition
tejinder
Go to solution Solved by Captain_WD,
~snip~
Hey there tejinder,
@KraftDinner made an excellent video tutorial!
Here's an official tutorial on how to partition and format a drive in case you ever need it: http://products.wdc.com/support/kb.ashx?id=2tQcsL
I also believe that this would be of help too: http://products.wdc.com/support/kb.ashx?id=CD1ZPV
Have in mind that shrinking partitions has its risks so a backup is always a good idea :)
Feel free to ask if you happen to have questions!
Captain_WD.
i got new laptop however there is just one partition of full drive that makes me un happy , i normaly like to have like 2-3 partitions
how can i make new partition with losimg original windows installed
Here you go, I made this video a while back it should help you figure out your situation, works with windows 7/8/10:
~snip~
Hey there tejinder,
Captain_WD.
If this helped you, like and choose it as best answer - you might help someone else with the same issue. ^_^
WDC Representative, http://www.wdc.com/
