SSD Boots Faster Than My Ethernet Can Connect
byalexandr
Go to solution Solved by S7117,
Yeah it says it doesn't have drivers for Win10 64-bit. Can I use Win8 drivers?
https://www.atheros.cz/atheros-network-drivers.html
yes
what motherboard do you have?
Okay, first world problem here, but my SSD boots into Windows and loads all of my programs before my Ethernet even has a chance to connect. Even when it starts connecting it takes around 20-30 seconds and it's really annoying as Steam tells me it can't connect when it's already launched. What's causing this? Is there a workaround or is it a hardware limitation/Windows limitation?
And while we're at it, can anyone tell me tf RaceRoom Experience won't launch? It gives me a stupid error telling me that it can't connect to the servers or something, error 11002, not 11003 like everyone else has when I searched i searched it on Google. Any idea? I've checked the files and restarted and all (which is why I'm posting this because my ethernet is pissing me off).
Thanks!
Edit: I have a Qualcomm Atheros AR8171 adapter running the default drivers that came with Windows 10. I get around 22-23 Mbps down and 2-3 Mbps up, and my router is the one AT&T gives you (I believe a Motorola NVG589), and I am on a fully wired connection, no powerline or Wi-Fi.
Not gonna lie.
I am not surprised.
Reputation is a Lifetime to create but seconds to destroy.
 CHRISTIAN MEMBER
What?
fixed post - it didnt show the quote.
 CHRISTIAN MEMBER
I get it sounds silly, but it's annoying me a bit. I need to know what to do, update the drivers? Is it a hardware thing?
Yeah it could be. I am getting ready to leave a go home so I will get back to ya.
 CHRISTIAN MEMBER
Here is my network adapter, just in case:
Qualcomm® Atheros® AR8171
And it's using the default drivers that came with Windows.
Thanks!
my wireless card turns on in like 3 sec, so sometimes I can beat it when typing in my password, but it usually beats me. I dont see how  ethernet is not connecting that fast.
try installing the motherboard's network adapter driver. might help... as for the ssd.. that naturally happens... only other things to do are get a cat6 ethernet cable which is extremely fast and make sure your router's ports are fast.
| Ryzen 9 3950X | EVGA 1200P2 | AMD 5700XT | ASUS Crosshair VIII Hero WiFi | G. Skill 4x16GB 3600Mhz CL16 F4-3600C16D-32GTZN | 2x1TB Samsung 980 Pro | Lian Li O11 Dynamic |
Yes, but it's like Windows isn't even looking for an Ethernet connection until 15-20 seconds have passed, then it sees it and takes about 3-5 more seconds to connect, and then it is connected. Can someone point me to the right drivers? I can only find the ones on Qualcomm's site ro Windows 8, and I'm not sure if AsRock has it on their site.
I know right? It's really weird. I think it's the stock Windows drivers.
yes
yes
http://www.asrock.com/mb/Intel/B85M-ITX/?cat=Download&os=Win1064
the bottom one is the one you need LAN
That's for the traffic management, it's not actually a driver.
Anyway I installed the new driver and rebooted (so fast, love this SSD) and the Ethernet hooked up in around 5 seconds. Faster but I'm wondering if it can already be connected before I log in or not? That would be ideal...
thats about as fast as it gets....
Dang. Well, thanks! It's faster than before so that's what counts.
