X8DTI Motherboard or Z800 motherboard?
I am doing a dual Xeon build. I already have my Xeons (x5560's) but, I can't decide if I should use this Supermicro X8DTI motherboard or HP's Z800. I know that the Z800 has some weird power connections but, there are some power adapters for that on ebay. I already have all my components but the motherboard. The z800 board looks like it would have better expand-ability and more usb headers as well as on board audio Etc.(not that I expect the audio to be good) There is also a blog online that shows someone else's findings and how they turned the z800 into their daily driver. If this helps make any deciding factors, I'll be using this system for gaming, a little bit of content creation, Twitch Streaming, folding@home and daily use. I would really appreciate any advice! Thanks! :D
X8DTI
not worth dealing with the hp headache
Rigs I've Built
The Striker i5 4590 @ 3.7 ||  MSI GTX 980 Armor X2 || Corsair RMX 750 || Team Elite Plus 8 GB || Define S || MSI Z97S SLI Krait
The Office PC i3 4160 @ 3.6 || Intel 4600 || EVGA 500B || G.Skill 8 GB || Cooler Master N200 || ASRock H97M Pro4
The Friend PC G3258 @ 4.3 || Sapphire R9 280X Tri-X || EVGA 600B || 8 GB Dell Ram || Cooler Master N200 || ASRock H97M- iTX/ac
The Mom Gaming PC A10-7890K @ 4.4 || iGPU + ASUS R7 250 ||  8 GB Klevv DDR3-2800 Mhz
X8DTI
What part do you consider the "headache"? Other than the odd power connectors (which i'm fine with tinkering with to find a solution)
