I need urgent help my PC keeps completely freezing ( Windows 10 Pro )
Gandek
This has been going on for a while now and it mainly happened during regular tasks like web browsing and watching videos. just now it happened during a live CS:GO match which it has never happened in surprisingly but it ended up throwing us the game... HERE IS WHAT I THINK YOU NEED TO KNOW TO HELP ME FIX THIS: I have Windows 10 Pro i upgraded from Windows 7 Ultimate as soon as it came out, the first few months i did not have any issues. My GPU is a Asus R9 280 and it's drivers are out of date (rocking the previous newest version ( 15.201 ) reason being is i can't for some reason update to the newest one the download gets stuck at one point forever... I never had prior issues updating my catalyst driver. So i always have to use the power button and turn on the PC again :/
MY RIG | Intel Core i5-4690K @4.4GHz | COOLER MASTER HYPER 212 EVO | ASUS Z97-A  | Mismatched 24GB RAM @1600MHz DDR3 | WD CAVIAR BLUE 1TB + PNY CS900 120GB | GIGABYTE AORUS RX 570 4GB | FRACTAL DESIGN FOCUS G | CORSAIR CX550M  | WINDOWS 10 | Acer GN246HL 24" 1080p 144Hz  | Glorious Model O- (Glossy White) Ducky One 2 Mini (White - Cherry MX Silent Red) MOBILE | OnePlus 7 Pro 256GB (Grey) | iPad Pro 10.5 64GB (Gold)  PREVIOUS ACCOUNT: CYANOG
go into safe mode and try to install the drivers there
PC freezing is commonly associated with poor or unstable PSUs or dying HDDs. In his case I am leaning towards the PSU giving in.
Any program to check how the PSU is doin?
use a different PSU and test
Can't afford a new PSU right now to check.
get http://www.cpuid.com/softwares/hwmonitor.html (the regular one not the Pro version)
and open it. after you have had a few of the slowdowns with the program running post a screen shot of the system voltages part of it. It should show how low the voltage has dropped on each one of your rails. Its not perfect but its free and should show if your having any major instability with your PSU's power output.
System CPU : Ryzen 9 5950 doing whatever PBO lets it. Motherboard : Asus B550 Wifi II RAM 80GB 3600 CL 18 2x 32GB 2x 8GB GPUs Vega 56 & Tesla M40 Corsair 4000D Storage: many and varied small (512GB-1TB) SSD + 5TB WD Green PSU 1000W EVGA GOLD
You can trust me, I'm from the Internet.
Already have that, my temps are always chill and low but il post the screenshoot in sec.
Leave it running for a while, while you play a game or hit one (or preferably a couple) the slowdowns So we can see the difference between the Min and Max for the board voltages.
Side note, what formatting did you use for your signature? I really like it. Like what font and size?
Edit: :) Looks awesome.
I would get your GPU driver problems ironed out first before you try anything else.  Download the latest from the AMD site and run DDU first to completely remove the old drivers and software.
http://www.guru3d.com/files-details/display-driver-uninstaller-download.html
well i did that and also did it in safemode
and it still gets stuck @ this crap fml.
When I did my latest driver update on my AMD (CPU & GPU) based rig I hang at that point for about 15 min. It was odd but eventually it pushed past and finished.
My wife's did the exact same thing
Ya it was strange because my Intel build installed the same exact drivers without a hiccup in about a min.
I'm installing the full package again (hopefully it finishes) because i don't have the AMD Catalyst Control center i need it to change my monitors saturation it wasn't actually in the options it just gave the gaming evolved app which i always uninstalled because it screwed my games settings...Is there a manual download for just the control center?
