setting up the skyrim performance monitor with MO
Kingcomicbook
So on reddit I saw a post that said I needed to change all the paths in the SPM so that it would load with MO. He said it should look something like this:
D:\Games\Steam\SteamApps\common\Skyrim\Mod Organizer\profiles\Profile 1\skyrimprefs.ini
BUT there is no mod organizer folder in my steamapps/common/skyrim folder! Where else could it be? I've run MO many times and it's worked fine.
It doesn't have to be there. It's just wherever you installed mod organiser.
Aragorn (WS): 250D | 6800k | 840 Pro 512GB | Intel 530 480GB  | Asus X99-M WS | 64GB DDR4 | Corsair HX720i | GTX 1070 | Corsair H115i | Philips BDM4350UC 43" 3840x2160 IPS
Gimli (server):  Node 304 | G4560 | ADATA XPG SX8000 128GB | 2x 5TB WD Red | ASROCK H270M-ITX/AC  | 8GB DDR4 | Seasonic 400FL
 Omega (server):                 Fractal Arc Mini R2 | i3 4130 | 500GB Maxtor | 2TB WD Red : Raid 1 | 3TB Seagate Barracuda | 16GB RAM | Seasonic G-450w
Alpha (WS): 900D | 4770k | GTX 780  | 840 Pro 512GB  | GA-Z87X-OC | Corsair RM 850 | 24GB 2400mhz | Samsung S27B970D 2560x1440
