Going to get a 980 Ti, but slight change in plans. Need help for different card please.
Ninja_Commander
Ok, I was planning on getting the EVGA 980 TI Classified, but then things changed like the price and maybe I should something different in the 980 TI range. I still need to have it with a water block cause I have a custom loop in mt system.  So I need help from you the LTT people on which is the best option go for that has a block ready for me to buy and good Price to Performance in terms of OC. Don't want to super extreme OC and what not but enough that it will help me in the long run.
CPU: 5900X   MOBO: MSI Tomahawk x570
MEM: G.Skill 32gb (2 x 16gb) 3600
GPU: Asus tuf oc 3080
May add the other bits of my system later on
Here. If you'll put a custom block on it, just get one with a reference PCB, it'll make your life easier.
Want to help researchers improve the lives on millions of people with just your computer? Then join World Community Grid distributed computing, and start helping the world to solve it's most difficult problems!
You think just getting teh standard card is more then enough for me to do some good OC ?
