Longer modular power supply cables
Go to solution Solved by Decon,
I recently purchased a EVGA Supernova 750W G2 PSU. My 8pin CPU connector is too short to route through the back of the PC case. I've never owned a modular PSU and am unsure how universal modular power supply cables are. I need to get one that is about 4-6 inches longer, in black. Quick search led me to frozencpu.com, but I am unsure how universally compatible these cables are. Helpful input, tips and recommendations are greatly appreciated.
Model for reference: http://www.amazon.com/EVGA-SuperNOVA-Crossfire-Warranty-220-G2-0750-XR/dp/B00IKDETOW/ref=sr_1_1?s=pc&ie=UTF8&qid=1451420402&sr=1-1&keywords=evga+supernova+750+g2
just get a sleeved 8pin extension in black
CPU: Core i7 4970K | MOBO: Asus Z87 Pro | RAM: 32GBs of G.Skill Ares 1866 | GPU: MSI GAMING X GTX 1070 | STOR: 2 X Crucial BX100 250GB, 2 x WD Blk 1TB (mirror),WD Blk 500GB | CASE: Cooler Master HAF 932 Advanced | PSU: EVGA SUPERNOVA G2 750W | COOL: Cooler Master Hyper T4 | DISP: 21" 1080P POS | KB: MS Keyboard | MAU5: Redragon NEMEANLION | MIC: Snowball Blue | OS: Win 8.1 Pro x64, (Working on Arch for dual boot) |
https://linustechtips.com/topic/516027-longer-modular-power-supply-cables/
Want a good game to play?  Check out Shadowrun: http://store.steampowered.com/app/300550/ (runs on literally any hardware)
another 12 core / 24 thread senpai...     (/. _ .)/     \(. _ .\)
Lol. Wow, hadn't even considered an extension cable. Never seen any, so it never crossed my mind. ^__^;
Looks like this will fit the bill.
http://www.amazon.com/Silverstone-Sleeved-Extension-Connector-PP07-EPS8B/dp/B00B46XJRU
where do you route the cable?
Currently using that case, but planning getting a Corsair C70 fairly soon. One of the reasons I am switching is this case's lack of cable routing and management options. I just know I'll need a longer cable because I want my PSU on the bottom of the case.
It wont be an issue. My G2 CPU cables are extremely long
the ax1200 has 610mm cpu power cables the g2 has 700mm
