Hi guys,
My girlfriend want to buy her littler brother a new pc.
His old computer (ddr2 old) is not working for couple of years.
We need the cheapest computer mainly for study and just browsing the web but the kid want to play a bit.
I think that as long as he'll be able to run games (not even at 1080p) it'll be ok.
I know he want to play CS GO mainly.
what do you guys think? what can we do for him?
I bought my Pc (4670K r9 290) more than a year ago so i really dont know what is going on these days, with the new gpu generation and cpu generations.
Thank You!!
*****************Edit*******************
he got http://www.aerocool.us/case/m40/m40-spec.htm this as the old case which we can use.
****************Edit********************
Hi guys,
Thank You!!
Budget and Currency?
CPU: i5 6600k OCed to 4.5Ghz @ 1.35v, GPU: R9 390 Nitro, Motherboard: Asus z170-A, CPU Cooler: H100i GTX, RAM: HyperX 2x8 16gb DDR4, PSU: Seasonic x650, Storage: 850 EVO 500gb, WD 1tb blue, Case: H440 White/Black
What is the exact budget? Or are you just trying to do as cheap as possible? What's the location? I mean, US/UK/AU etc?
CPU: AMD Ryzen 7 5800X3D GPU: AMD Radeon RX 6900 XT 16GB GDDR6 Motherboard: MSI PRESTIGE X570 CREATION
AIO: Corsair H150i Pro RAM: Corsair Dominator Platinum RGB 32GB 3600MHz DDR4 Case: Lian Li PC-O11 Dynamic PSU: Corsair RM850x White
budget?
budget?
follow thread @Naimdor
RIG #14670k @4.4 / 1.25v vcore. @ 4.5 / 1.3v vcore/ 1.95v vccin. MSI GAMING 4G GTX 970 @1540/3700 1.275v BIOS MOD. 16GB Kingston HyperX Savage RAM 2400mhz. MSI GAMING 5 Z97 MOBOFractal Design Define S. Dark Rock Pro 3. 850 EVO 250GB Seasonic M12II 620w
RIG #2: 4790k @ 4.6 / 1.25v vcore. EVGA SC ACX 2.0 980 SLI16GB Corsair Vengeance Pro 2400mhz. Asus MAXIMUS VII Hero Z97. Fractal Design Define R5. NH D15. 850 EVO 250GB AX 860
If we're talking new, for 300$ you can get a build that's capable of running games like Battlefield 4/GTA V at playable framerates:
CPU: AMD A10-7850K 3.7GHz Quad-Core Processor  ($112.43 @ Amazon)
Motherboard: Gigabyte GA-F2A88XM-D3H Micro ATX FM2+ Motherboard  ($55.99 @ SuperBiiz)
Memory: G.Skill Ares Series 8GB (2 x 4GB) DDR3-2400 Memory  ($29.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($49.98 @ OutletPC)
Case: Cooler Master N200 MicroATX Mid Tower Case  ($29.99 @ Newegg)
Power Supply: EVGA 600B 600W 80+ Bronze Certified ATX Power Supply  ($24.99 @ NCIX US)
Total: $303.37
Generated by PCPartPicker 2015-12-29 10:29 EST-0500
I'm from israel so currency is not gonna help.
Lets say around 500US which means 2000 in my currency.
if a specfic part will cost more here then in the us so i will tell you and i hope we will find something to replace.
I foegot to tell you we dont need a case!!
Total: $303.37
Thanks!
no gpu at all? will the onboard be enogh?
Thanks!
Yes, the iGPU in these little APUs is amazing in what it can do.
Watch this:
It's the lowest-end build you should get, will run CS:GO great.
Not sure how well it'll translate to Israeli currency but here's a good build for $500 USD:
CPU: Intel Core i3-4170 3.7GHz Dual-Core Processor  ($107.99 @ NCIX US)
Motherboard: ASRock H97M Anniversary Micro ATX LGA1150 Motherboard  ($67.99 @ SuperBiiz)
Video Card: PowerColor Radeon R9 380 4GB PCS+ Video Card  ($193.98 @ Newegg)
Total: $501.93
Generated by PCPartPicker 2015-12-29 10:34 EST-0500
Alternatively, going with @Morgan MLGman's build is what I'd recommend personally. It's a lot cheaper and should definitely be within your budget regardless of currency, and will run CS:GO fine.
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
