Why leaning an engine out is bad?
I never got why not supplying the engine with enough fuel is detrimental in the long term... Wont the engine just cut out?
Having more air than fuel in the combustion chamber seems safer than having more fuel than air...
Cpu: Ryzen 2700 @ 4.0Ghz | Motherboard: Hero VI x370 | Gpu: EVGA RTX 2080 | Cooler: Custom Water loop | Ram: 16GB Trident Z 3000MHz
PSU: RM650x + Braided cables | Case:  painted Corsair c70 | Monitor: MSI 1440p 144hz VA | Drives: 500GB 850 Evo (OS)
Laptop: 2014 Razer blade 14" Desktop: http://imgur.com/AQZh2sj , http://imgur.com/ukAXerd
The mixture burns lean which increases the heat and therefore the wear
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
Ahh. The only thing I guessed was that the fuel lubricated the pistons a bit, so not having enough of it would warp the cylinders or something...
Its a little more complex than that, involves timing and hot spots etc
Ryzen Ram Guide
Quite simply, an engine likes to have a certain ratio of air per part of fuel. If you take out too much fuel, the mixture wont properly combust. It creates more heat and can lead to things like a misfire (detonation is the proper term for it) and when a misfire happens, there is a potential for catastrophic failure. Like a piston exploding and taking out an entire engine block leaving holes in the oil pan.
Do you even fanboy bro?
In diesel engines this is true and also providing lubrication for the fuel system but petrol engines don't get any additional lubrication from the fuel.
DESKTOP - Motherboard - Gigabyte GA-Z77X-D3H Processor - Intel Core i5-2500K @ Stock 1.135v Cooling - Cooler Master Hyper TX3 RAM - Kingston Hyper-X Fury White 4x4GB DDR3-1866 Graphics Card - MSI GeForce GTX 780 Lightning PSU - Seasonic M12II EVO Edition 850w  HDD -  WD Caviar  Blue 500GB (Boot Drive)  /  WD Scorpio Black 750GB (Games Storage) / WD Green 2TB (Main Storage) Case - Cooler Master 335U Elite OS - Microsoft Windows 7 Ultimate
