Gtx970 g1 Windforce edition overclock @ 1500mhz or 1.50mhz
Mitchell158
In Jayztwocents video:https://m.youtube.com/watch?v=OAahjdwfbRw he talks about getting the card to 1500mhz and I was wondering what settings I had to change to get it to stop crashing when I start a game. I just need to know the exact setting of voltage, memory, and fan speed and all the others. Thanks!
Even with the same settings, cards are not guaranteed to be stable.
not guaranteed your card will do 1500 mhz. overclocking is not quick and dirty,
you need to increase core clock until you crash.. if you crash at less than 1500mhz then either increase voltage or lower the oc..
RIG #14670k @4.4 / 1.25v vcore. @ 4.5 / 1.3v vcore/ 1.95v vccin. MSI GAMING 4G GTX 970 @1540/3700 1.275v BIOS MOD. 16GB Kingston HyperX Savage RAM 2400mhz. MSI GAMING 5 Z97 MOBOFractal Design Define S. Dark Rock Pro 3. 850 EVO 250GB Seasonic M12II 620w
RIG #2: 4790k @ 4.6 / 1.25v vcore. EVGA SC ACX 2.0 980 SLI16GB Corsair Vengeance Pro 2400mhz. Asus MAXIMUS VII Hero Z97. Fractal Design Define R5. NH D15. 850 EVO 250GB AX 860
what do u mean?
It's all Silicon Lottery M8.  You aren't even guaranteed an overclock on a card.  Request a custom BIOS here and it most likely will be able to go higher.  http://linustechtips.com/main/topic/327032-gtx-970-owners-club/
i5-4690k@4.5GHz || MSI GTX 970 || MSI z97 Gaming 5 || NZXT Kraken x61 || WD Black 1TB || Crucial MX100 || 8GB Corsair Vengeance Pro || Corsair RM750 || NZXT H440 || Corsair k70 RGB mx browns || Acer H236HL || ViewSonic VX2255wm-4
what do u mean?
Every card is different. You could have the exact same settings and your card could still fail, or it might clock itself higher.
A lot of the 970 g.1s overclock rather well. I got a nice 1513 boost on mine, but that's at max voltage and instability in some less optimized games. Just follow Jay's overclocking guide and hope for the best.
ASU
with my 980 G1 gaming  (yes i know different card i just dont have a 970) i did +150 core for a 1527mhz core and all cards are different one might get 1600 when a nother might crash when you add +1.
