Question with cameras and monitors
Colt_0pz
Why is it that whenever you look at a monitor through a camera that the display flickers? how can the camera pickup this flickering and the human eye can't. My display runs at 144hz
Out of sync. Camera and monitor.   and with the filters on top of the screen, and it is the backlight flickering most likely. (in the most basic explanation)
Human eye blurs it.  (in the most basic explanation)
Camera shutter speed and video frame rate vs. monitor refresh rate.  The human eye doesn't have a shutter, it processes images continuously.  But a camera's image sensor has to have a shutter, either mechanical or electronic.
Guide: DSLR or Video camera?, Guide: Film/Photo makers' useful resources, Guide: Lenses, a quick primer
Nikon D4, Nikon D800E, Fuji X-E2, Canon G16, Gopro Hero 3+, iPhone 5s. Hasselblad 500C/M, Sony PXW-FS7
ICT Consultant, Photographer, Video producer, Scuba diver and underwater explorer, Nature & humanitarian documentary producer
To put is simply, a display flickers on a camera when your camera fps is lower or higher (cannot remember which) than the refresh rate on your display.
My Rig:
Xeon E5 1680 V2 @ 4.5GHz - Asus Rampage IV Extreme X79 Mobo - 64GB DDR3 1600MHz - 8 x 8GB Corsair Vengeance Low Profile - CAS 10-10-10-27 - AMD Radeon RX 6700XT Sapphire Pulse 12GB - DeepCool E-Shield E-ATX Tempered Glass Case - 1 x 1TB Crucial P1 NVMe SSD - BeQuiet Straight Power 11 850W Gold+ Quad rail - Fractal Design Celsius S36 & 6 x 120mm silent fans - Lenovo KBBH21 - Corsair Glaive RGB Pro - Windows 10 Pro 64-Bit
Monitors - 3 x Acer Nitro 23.8" 1080p 75Hz IPS 1ms Freesync Panels = AMD Eyefinity @ 75Hz
Same phenomenon, ish.
hmm. quite similar to what i see. My phone's camera runs at 60hz and my display runs at 144hz
Most monitors use high-speed flickeringto controp brightness. Turning the brightness of the monitor up to 100% will usually eliminate the flickering if you need to film something on it.
nah. i find the flickering cool
