Graphics card possibly failing post?
Tractorman990
Hey,
First specs:
MSI 970 Gaming Motherboard
AMD FX 8370
Asus Strix GTX 970
16 GB Hyper X Memory
Corsair Rm750i PSU
and a total of 4.128 TB of space
When i try to boot my rig i get a post beep code 1 long 2 short and i don't know what is happening the fans are spinning the lights are on and everything seems fine so i tried re-seating my GPU and ram and that didn't work i tried to go through a DVI to VGA converter and still nothing the CPU is working because the heat sink fins are hot and I don't know what else to tell you.
Cheers in advance,
Tractorman990
