Okay so im getting a new monitor soon... which of the 2 monitors should i get below? Both of these monitors are compatible with my build. *NOTE* (if you have another suggestion you can post it)
(I have a i7-4790k, and a Radeon R9 390)
-BenQ XL2730Z
-Acer XG270HU
                                           I need something with Freesync for AMD, and i love 144hz and 1440p. THANKS!
https://linustechtips.com/topic/514654-help-which-monitor-should-i-get/
