The power to the fan has a problem
George_Bud
I have an old laptop that has some problems. The fan is ok. I test it and it works. The fan need at least 3.5 v to work. But when I put the fan connector in its socket ( I think this is the correct term to it ), at first I get 5.4 v but then after aprox. 30 seconds I get 0.3 v and the fan stops spining. And because the fan is not spining the laptop is overheating.
Any suggestion or hacks, components, advice ?
P.S.
If you need any aditional information about the laptop, please ask. :)
Moved to Troubleshooting.
Can you change the fan profile in the bios?
No. I dont have any fan options or power options in the bios. I only have main, advance, security, boot and exit.
