GPU Articafting problem
Taswell
I have had an r9 290 reference edition from sapphire for about 3 months now and about 1.5 months ago it started giving me really minor  Articafting that has been eating at my brain for awhile and i cant figure out how to stop it.
Ihave one of the corsair hydro adapters on there right now so my thoughts is maybe some of the vram is overheating? (even-though its a full cover block)
Some games are worse than others and it seems to happen at random.
like dota 2 the bottom left corner occasionally flashes white then back again ( its in windowed mode and the edge of the desktop is included so its not limited top the render area)
witcher 3 is fine
cs-go is occasionally (kinda rare)
stuff I've tried:
Driver rollback
stock speeds
fan curve increase
enable/disable vsync
Current: R2600X@4.0GHz\\ Corsair Air 280x \\ RTX 2070 \\ 16GB DDR3 2666 \\ 1KW EVGA Supernova\\ Asus B450 TUF
Old Systems: A6 5200 APU -- A10 7800K + HD6670 -- FX 9370 + 2X R9 290 -- G3258 + R9 280 -- 4690K + RX480
Full SPECS?
Signature
Have you tried pulling back on the overclock?
yep stock speeds
yep stock speeds
Hmmm. You could try a DDU and re install of the drivers. But you might have to RMA it.
If anyone asks you never saw me.
