Monitor mount
TheWildLamb
I would like to get a new monitor but i want it attached to the wall but so it is movable on an arm any ideas of a monitor and the arm.Thank you
I am using a BenQ XL2720Z 27” Monitor on a Humanscale M8 Monitor Arm. The monitor is choice but the monitor arm is important. The M8 can support 40 Lbs. and the adjustment is excellent. They retail for $399.00 but can be found on eBay for between $65.00 to $150.00 most of the time and they are built like a tank. The wall attachment arms show up occasionally and are usually in the same price range.
