Best low cost SSDs
l__T__l
I want to buy 2 SSDs to put in raid 0 and have at least 240GBs of storage.
Many sources name the 850 EVO as the best budget SSD, however it seems to be just as good as SSDs $20 less than it. I have around $125 USD to spend on drives but would prefer to keep it below $100, do you guys have any recommendations.
What are your thoughts on the BX200, I can afford 2x240GB drives otherwise I have to stick with 240GBs.
1 higher quality is ALWAYS better than 2 lower quality.
2 lower quality disks will have alot higher failure rate than a just one good disk. At least 2X due to them being of lower quality.
Crucial SSDs are a good pick budget wise. Just run crystal disk mark as soon as you get them to make sure they are fine.
Fine you want the PSU tier list? Have the PSU tier list: https://linustechtips.com/main/topic/1116640-psu-tier-list-40-rev-103/
Stille (Desktop)
Ryzen 9 3900XT@4.5Ghz - Cryorig H7 Ultimate - 16GB Vengeance LPX 3000Mhz- MSI RTX 3080 Ti Ventus 3x OC - SanDisk Plus 480GB - Crucial MX500 500GB - Intel 660P 1TB SSD - (2x) WD Red 2TB - EVGA G3 650w - Corsair 760T
Evoo Gaming 15"
i7-9750H - 16GB DDR4 - GTX 1660Ti - 480GB SSD M.2 - 1TB 2.5" BX500 SSD
VM + NAS Server (ProxMox 6.3)
1x Xeon E5-2690 v2  - 92GB ECC DDR3 - Quadro 4000 - Dell H310 HBA (Flashed with IT firmware) -500GB Crucial MX500 (Proxmox Host) Kingston 128GB SSD (FreeNAS dev/ID passthrough) - 8x4TB Toshiba N300 HDD
Toys: Ender 3 Pro, Oculus Rift CV1, Oculus Quest 2, about half a dozen raspberry Pis (2b to 4), Arduino Uno, Arduino Mega, Arduino nano (x3), Arduino nano pro, Atomic Pi.
BX200 is the best cheapest drive from a trusted brand you can get, and they're $65 USD each for 240GB.
If you're willing to take a risk, this exists:
www.amazon.com/gp/product/B015ZGXGI6
and the initial speed tests look great, but we have no data on longevity. I ordered one myself because I really needed a drive and it's so cheap, but you may prefer to not go with an unknown.
I've heard quite a few bad things about the BX200 but that might just be from SSD snobs.
I find it hard to believe that it would be twice as likely to fail. I also find it quite hard to believe that 2x working together with quite efficient scaling would do worse than a single drive that can only reach 6Gb/s anyway.
It seems to have a 3 year warranty, definitely considering it. As long as I back it up I have nothing to worry about for 3 years.
It's unlikely but twice the rate. Perhaps even more.
with one drive it's the mobo and the 1 drive.
with 2 drives it need to read from both drives and piece together the data meaning more space for errors.
If budget is really a problem then it'll be just fine. it's a reliable brand and has very good performance for the price.
Make sure your motherboard support RAID if not, a raid card may cost more than your savings on the SSD.
sorry, I kind of blanked on that obvious fact.
u can find a sandisk ultra ii 480gb for 140 usd, if you can stretch your budget about 15$
The site has changed....
Where? That sounds like an excellent deal.
EDIT: found it, will consider but I have since lowered my budget. I'll probably just end up with a single Faspeed f710 240GB
