change the 970 to a r9 390 other than that looks good
This ^^^^^^^
Intel Core i3 2100 @ 3.10GHz - Intel Stock Cooler - Zotac Geforce GT 610 2GB Synergy Edition
Intel DH61WW - Corsair® Value Select 4GBx1 DDR3 1600 MHz - Antec BP-300P PSU
WD Green 1TB - Seagate 2.5" HDD 1TB - Seagate Barracuda 500GB - Antec X1 E.
I wanna add some stuff to my system, since i want to future proof a bit.
So are these good together http://pcpartpicker.com/p/hBMchM
(I don't want to upgrade to skylake or ddr4 stuff)
What's your PSU? Also, I'll give you the typical LTT forum answer when you have a GTX 970 in your build - get a 390 instead.
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
You can't future proof.
Though the parts fit nicely
I would choose a sapphire r9 390 instead of the 970 ;)
MSI Z97 Gaming 5 | I5-4690k| Dark Rock Pro 3 | ASUS RX480 |  Kingston HyperX Beast 8GB | Samsung 850 EVO 250Gb|
   Playstation Pulse Headset Corsair Air 540 | Deiog DY-200 | AOC G2460Fq
Dell Keyboard | 6x BeQuiet Silent Wings PWM 120mm
Built  Not Bought
in terms of compatibility, it's completely fine :D
But the 390 is a better GPU therefore I would recommend to change it to that (but also depends on how good your PSU is).
Looking at my signature are we now? Well too bad there's nothing here...
What? As I said, there seriously is nothing here :)
R9 390 > 970
And older Energon EPS-750 watt
That one look like a crappy.
Please don't use that.
It could damage your system very easily.
Get an EVGA G2/GS/GQ PSU or any Seasonic PSUs.
I'd swap it out if I were you. Here's your new parts including a PSU I recommend:
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor  ($329.99 @ SuperBiiz)
Motherboard: MSI Z97S SLI Krait Edition ATX LGA1150 Motherboard  ($104.99 @ SuperBiiz)
Video Card: Gigabyte GeForce GTX 970 4GB WINDFORCE 3X Video Card  ($324.99 @ NCIX US)
Power Supply: XFX 550W 80+ Bronze Certified ATX Power Supply  ($55.99 @ SuperBiiz)
Total: $899.94
Generated by PCPartPicker 2015-12-26 09:02 EST-0500
Total: $899.94
Im a corsair fanboy. Any good corsair psu?
The 970 gets 3.5/4 from me  B) Yeah, you're better off with switching out to an R9 390. On the PSU front, you can't go wrong with Corsair, EVGA, Seasonic and Fractal Designs. Heard great things from those brands. I've been using a Corsair HX750 for the past two years. No issues. Another thing to consider would be wattage too, depends on your future upgrade path.
Social Links: LTT Forum    Website    Instagram    Twitter    YouTube    LinkedIn    Steam
The Build
CPU Intel i7 4770k 4.4ghz Motherboard Asus Sabertooth Z87 RAM 34gb (4 x 8gb) Corsair Vengeance 1600mhz GPU Evga GTX780 Classified Case Lian Li O11 Dynamic Storage Samsung 840 256gb SSD PSU Corsair HX750 Display Achieva Shimian QH300-IPSMS 1600p Cooling Corsair H100i Keyboard Corsair K90 Mouse Corsair M65 Sound 3.1 Surround Sound Fans 2x Corsair SP120 PWM, 3x Corsair AF140 Q.E, and 1x Corsair AF120 Q.E.
I generally dislike the CX and VS series, and since they're pretty much the only ones in your range, I'm afraid not.
Check this thread for Whitelist of PSUs.
http://linustechtips.com/main/topic/404921-strmfrmxmns-psu-whitelist/
