Strafe RGB plate mounted switches ?
Go to solution Solved by jimakos234,
Does anyone know for sure if the Corsair Strafe RGB has plate mounted switches like the original Vengence K70 .
if anyone has experience using the original Vengence K70 non RGB ( red backlit LED's )
Does the key press feel the same on the strafe RGB as the original Vengence K70  -  lets say both the keyboards use Red or Brown switches - Does the keypress feel the same.
I've seen that the Strafe RGB has a plastic white background under the switches - are the key switches mounted to this plastic plate - like the switches are mounted to the aluminum platye on the original Vengence K70 ?
yes the switches are mounted to the plastic plate on the strafe(i got the strafe rgb), making the rgb lights to show better/brighter, the led on the left and right doesnt interfere with the other colors, but its color cant be changed, it is just a plain white led.
I7 8700K - 4.7 OC , Asrock Z370 Extreme4 MB, MSI GTX 970 ,  NZXT H440 , Corsair H110 , 16gig Balistix ram  , Razer Huntsman Elite - Razer Purple Opto-Mechanical Key Switches  -   , Logitech G502 , Samsung 850 Pro bootup drive, Antec Edge 750 modular PSU
https://linustechtips.com/topic/512740-strafe-rgb-plate-mounted-switches/
The site has changed....
Yes it's plate mounted. You can't actually buy any keyboards that are not plate mounted these days (although cherry may have a couple of their own boards without plates)
Hey! New SIgnature!
I'm supposedly a person on the Internet, but you'll never know if I'm human or not ;)
