Intel i5 4460 vs i5 4690k, is there a huge difference?
Hey, is there really a huge difference between the Intel i5 4460 vs i5 4690k? (not the price)
The only reason to get the i5 4690k would be overclocking, but is overclocking really that noticeable? (I would probably not overclock anyway, just wondering)
Otherwise, what is the difference between these two CPU's?
Thanks!
stock for stock? No
stock vs OC? Yes
stock for stock? No
stock vs OC? Yes
Alright, well that is what I thought. However to overclock you need a specific type of motherboard, right? And when trying to overclock, how much better would it run?
I would use it for gaming and streaming / recording.
Besides the base clock and the fact that the 4690k can overclock, it's not gonna be a big difference at stock. Once overclocked though, depending on WHAT, it can make a very big difference.
I would use it for gaming and streaming / recording. How big of a difference is there after OC?
Consider a Xeon 1231v3 for that.
There's a rather large difference between the two when the k is overclocked.
USEFUL LINKS:
PSU Tier List F@H stats
The z97 boards aren't that expensive anymore, so if you can afford the 4690K get it
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
Totally agree with that.
You are getting extra 4 threads for similar or same kinda price.
It's really worth.
Intel Core i3 2100 @ 3.10GHz - Intel Stock Cooler - Zotac Geforce GT 610 2GB Synergy Edition
Intel DH61WW - Corsair® Value Select 4GBx1 DDR3 1600 MHz - Antec BP-300P PSU
WD Green 1TB - Seagate 2.5" HDD 1TB - Seagate Barracuda 500GB - Antec X1 E.
But why? It is a lot more expensive than the i5 4690k, but is pretty much the same?
Thanks!
There will be no difference at stock speed. but if you overclock the 4690k then there will be a difference between the 4460.
If you're not overclocking then the i5 4460 is for you, if however you will be overclocking in the future then just get the i5 4690k :)
Merry Christmas!
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
It's really worth.
Sorry, but from Sweden.. so here, not the same price at all. It is like nearly 100 USD more! For nothing!
Merry Christmas!
Thank you, I will keep that in mind.
Z97 for OC
Xeon E3 1231v3 is much better than a i5 for streaming/rendering
It's not nothing.
It's 4 extra threads. It's basically a 4770 without iGPU.
Works better for Streaming or Video Editing.
For another 4 threads. (4 cores 8 threads on the Xeon)
Oh, didn't notice that xD Alright, well.. that is all great and stuff, but still a lot more expensive.
It's not nothing.
If it's nothing, why not throw some cash to me? ;) But yeah, I just noticed that it had 4 more threads, but yeah, I can't stretch that far.
I said "It's not nothing" :P
Then you should stick with a 4460. No other way.
Or wait for few weeks, save up. Then buy 1231 V3.
What about the AMD FX 8350 then? It is WAY cheaper than both Intel i5's and it it 4ghz and it is 8 cores and 8 threads.
Haha, woops. Well what about the AMD FX 8350 then? It is WAY cheaper than both Intel i5's and it it 4ghz and it is 8 cores and 8 threads. The only reason I have heard so far is "intel is better" but this cpu is clearly better!
Please don't.
Those are dead sockets. Way older.
Still an i5 can beat the FX 8350 in many ways.
Don't fall for "8 core".
Those are weaker "8 cores".
Choose i5 now, and you have better upgrade path later.
4690k w h100gtx passing by... go for the e3 you'll have to spend extra money on a good cooler to get a good overclock (although the lottery matters too!). however if you are sure that you will upgrade to an unlocked processor in the future, might as well get an 4690k and spend some extra money on the cooler, you can reuse it your next build!
Cpu: i5 4690k @ 4.3ghz
Gpu: Asus GTX 970 Strix
Ram: G.Skill Ripjaws 16GB
Mobo: Gigabyte Z97X Gaming 5
Psu: EVGA Supernova 750W G2
Case: NZXT Noctis 450
You can't overclock Xeons?
USEFUL LINKS:
