Corsair Air 540 noise advice needed
absinth92
I was wondering if someone could provide me some sort of solution for this. I just ordered the Air 540 case to be delivered next week. With my setup, I'll only be using the three fans provided and one additional 120mm fan on my Hyper 212 EVO. The top of the case has room for two 140mm fans but I don't have any need for additional cooling. Instead, I was hoping to completely block out the top underneath the vent. I don't want to put something literally on top of the case, just underneath the vent. My goal is to slightly reduce noise from inside the case. I know it won't make much of a difference but I'd still like to try something.
Just in case it's relevant to ideas people think of, I'm going for a pure white and black setup.
with the VERY noisy fans you get with the case it wont matter at all, otherwise you can buy sound dampening materiel in the store, i know silverstone has some they sell that you cut and glue in.
Proud Member of the Glorious PC Master Race
