Fan config for AIO
txb
So for Christmas I just bought myself a H110i GT AIO liquid cooler. I was just wondering if I should try putting it in the top of my case, or if I could get enough airflow putting it in the front of my case. Also would you recommend a Push, a Pull, or a Push/Pull fan config. Thanks!
Most common way is to put it in the top and have air push through it, putting it in the front would also be fine but also do a push config. If you have the space and can spare the fines you can do a push/pull but you won't notice major temp differences by doing this.
Merry Christmas!
Gaming Desktop - AMD Ryzen 7 5800X, MSI MPG B550 Gaming Plus, 32GB Cosair Vengenace LP 3600mhz, EVGA RTX 3070 XC3 Ultra,  Sabrent Rocket 4 1TB NVME SSD, WD Blue SN570 NVME SSD, 4TB Mass storage, EVGA 750W G2, Corsair 270R
Firstly, what is your pc case?
Also, don't forget to follow your threads. @txb2
Shot through the heart and you're to blame, 30fps and i'll pirate your game - Bon Jovi
Take me down to the console city where the games are blurry and the frames are thirty - Guns N' Roses
Arguing with religious people is like explaining to your mother that online games can't be paused...
I have an Obsidian 750D
Merry Christmas!
Thank you very much! I will definitely make sure to have the fans on the radiator be exhaust!
In that case, i'd personally do a pull setup with the radiator fans, at the front of the case. It's what i've done in my Fractal R5, with a H110i GTX.
Thanks and merry Christmas
