Xbox one controller pc adapter problems/ .net framework 3.5 error
I bought a wireless adapter so I can play pc games with my xb1 controller. I plug it in and it installs default drivers. My pc does an update at restart, but gets stuck at 83% and cancels the update after about 25 minutes. I tried uninstalling the drivers and plugging the adapter in to reinstall drivers. Same thing. I tried downloading the drivers from Microsoft and manually installing them in device manager. It said they were the right drivers but Windows failed to install them. So I said **** it, I'll just install Windows 10. Awesome, it works. But now my game doesn't work because win10 doesn't come with .net framework 2-3.5. So I go and download .net framework pack(2.0,3.0,3.5), but every time I try to install it, it fails! WTF!!! Listen man, I'm just trying to play some La Noire and want my stuff to work. Please help.
10 comes with 4.6
but la noire should be fine with it
install the directx and it should work
if this was a clean install of 10
if not do the clean install first
If you need remote help fixing something on your computer
I can help over Teamviewer if you wish
just msg me on my profile
When I updated to Windows 10 and tried updating, it started downloading cumulative Windows update, but failed every time it tried to install. And gave me an error message
sounds like you onlt did the upgrade
