Monitor Not Going to Sleep
stoneoxmike
After installing NVidia driver version 361.43, my monitor hasn't been falling asleep and turning off after a time period of not using it.  I checked my settings in the monitor's menu, and it is set up correctly.  My monitor is the Asus VS228H-P.  I was just wondering if anyone was having the same issue and had a fix yet.
CPU: i5-4690K @ 4.3GHz | GPU: MSI GTX 960 Gaming 4G | RAM: 8GB Corsair Vengeance Pro | Motherboard: ASUS Z97-P | Case: CM HAF Stacker 935 | PSU: Corsair CX430
If you monitor has drivers, try reinstalling it?
Have a look at Windows power settings as well.
There aren't any drivers on Asus' website, and Windows settings were set up correctly as well.
