850W Dark Power Pro enough?
Hey guys,
I just got a 850W beQuiet Dark Power Pro and a second GTX 980. According to my calculation it should barely be enough for my OC (4.5 Ghz) 4790K and the 2 (overclocked to 1300mhz) 980s. What do you guys think? Should I exchange it for a 1000W Power Zone after Christmas?
Thanks in advance
Yeah should be fine but i would get a better PSU that is a pretty "meh" one.
I3-4150 | Be Quiet! Dark Rock Pro 3 | 8GB KINGSTON FURY RAM | MSI Z97-G43 | HYPERX FURY 120GB SSD SAPPHIRE HD7950 VAPOR-X | Phanteks Enthoo Pro M | EVGA 500W | Corsair SP120's w/ NZXT Fan Hub
Plans: I5-4690K || EVGA GS 650W | KINGSTON FURY 8GB RAM  PCPARTPICKER: https://uk.pcpartpicker.com/
60FPS Microwave
Intel Core i5-4670K | Galax GTX 970 EXOC | ASRock Z97E-ITX/ac | Team Elite 8GB 1600MHz | Gelid Black Edition | Samsung slowdown + WD Blue 1TB x2 | Cooler Master V550 | Corsair K65 + Logitech G100s | MasterCase Pro 3
What would you suggest? That is a pretty fine PSU
http://linustechtips.com/main/topic/334934-unofficial-ltt-beginners-guide/ (by Minibois) and a few things that will make our community interaction more pleasent:
1. FOLLOW your own topics        2.Try to QUOTE people so we can read through things easier
3.Use
PCPARTPICKER.COM - easy and most importantly approved here        4.Mark your topics SOLVED if they are
Don't change a running system
Hey guys,
Thanks in advance
What do youmean by barely enough?
What 980 do you have?
let's calculate that approximately:
2*250W(GPUs) + 150W(CPU) + (other stuff) 100W = 750W and that is probably the worst you will ever get. 250 Watts is overkill for a 980, 150 is overkill for 4790k and you other stuff will never ever consume 100W. Where is the "barely"?
3.Use
Hey guys,
Thanks in advance
Kid, you could run 4 non OCd 980s off 850W....
|PSU Tier List /80 Plus Efficiency| PSU stuff if you need it.
My system: PCPartPicker || For Corsair support tag @Corsair Josephor @Corsair Nick || My 5MT Legacy GT Wagon ||
