How do i set corssfire for dual 390x
Bajantechnician
Go to solution Solved by App4that,
gta v?
and the games that amd shows to incorporate crossfire?
A crossfire profile doesn't mean crossfire will give you any benefit. In all the games with profiles I had I only broke even with the performance of only one of my GPUs being used. Which was better than most of the time using crossfire where I lost fps.
Go into the Catalyst Control Center through Crimson in the additional settings tab and set Crossfire to enabled.
If anyone asks you never saw me.
Go to "preferences" -> "additional settings"
catalyst has dissapeared off the face of the earth for me
idk y
from where
Open Crimson, bottom of the UI, additional settings.
dont see anything for crossfire
do see the additional settings
Once in CCC I think it's in Gaming, might be video settings too. They keep changing it.
i heard amd drivers are nutorious
gaming tab is tessalation, aa, shaders
video settings is all cinema, outdoor, gaming, the way the video is shown
Wait how can you not find it... I found it just by clicking all the tabs when I first got crimson, but idk were it is, because I don't use crossfire.
You should see "Radeon Additional Settings " at the top of the UI. On the left are tabs, one of those should open to show the crossfire enable function. Or go to System in Crimson then Hardware. One of the GPUs will say (primary) and the other should say (linked). If it says (disabled) or doesn't show up you have a problem.
cuz im dumb
in radeon additional settings, it says
"currently installed 1.3.............."
then to the right it says check for unpated.
Thats it.
however, it says primary and linked.
and idk if this has to do with anything for crossfire, but my gta v profile is loaded in crimson
Open Crimson, at the top right click on "System". Now the top right should say "hardware" and list the GPUs connected to the PC. After each GPU it will say something what does it say?
first tab
Overview
Second tab
Software
Third tab
AMD Radeon 390 series #3 (Linked)
Forth Tab
AMD Radeon 390 series #1 (Primary)
You're golden. In "gaming" at the top right of the Crimson UI you can set the Crossfire profile for each game. Don't expect much though, very limited crossfire support. Why I sold my second card.
lol, all this time, and i  think it auto did it xD
Thanks, will i get at least the power of a titan z out of this tho?
Here are the step-by-step with screen captures (click on the pictures to enlarge).
Capture0
Capture1
Capture2
Capture3
Intel Z390 Rig ( *NEW* Primary )
Intel X99 Rig (Officially Decommissioned, Dead CPU returned to Intel)
  • i7-8086K @ 5.1 GHz
  • Gigabyte Z390 Aorus Master
  • Sapphire NITRO+ RX 6800 XT S.E + EKwb Quantum Vector Full Cover Waterblock
  • 32GB G.Skill TridentZ DDR4-3000 CL14 @ DDR-3400 custom CL15 timings
  • SanDisk 480 GB SSD + 1TB Samsung 860 EVO +  500GB Samsung 980 + 1TB WD SN750
  • EVGA SuperNOVA 850W P2 + Red/White CableMod Cables
  • Lian-Li O11 Dynamic EVO XL
  • Ekwb Custom loop + 2x EKwb Quantum Surface P360M Radiators
  • Logitech G502 Proteus Spectrum + Corsair K70 (Red LED, anodized black, Cheery MX Browns)
AMD Ryzen Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
Intel Z97 Rig (Decomissioned)
  • Intel i5-4690K 4.8 GHz
  • ASUS ROG Maximus VII Hero Z97
  • Sapphire Vapor-X HD 7950 EVGA GTX 1070 SC Black Edition ACX 3.0
  • 20 GB (8GB X 2 + 4GB X 1) Corsair Vengeance DDR3 1600 MHz
  • Corsair A50 air cooler  NZXT X61
  • Crucial MX500 1TB SSD + SanDisk Ultra II 240GB SSD + WD Caviar Black 1TB HDD + Kingston V300 120GB SSD [non-gimped version]
  • Antec New TruePower 550W EVGA G2 650W + White CableMod cables
  • Cooler Master HAF 912 White NZXT S340 Elite w/ white LED stips
AMD 990FX Rig (Decommissioned)
  • FX-8350 @ 4.8 / 4.9 GHz (given up on the 5.0 / 5.1 GHz attempt)
  • ASUS ROG Crosshair V Formula 990FX
  • 12 GB (4 GB X 3) G.Skill RipJawsX DDR3 @ 1866 MHz
  • Sapphire Vapor-X HD 7970 + Sapphire Dual-X HD 7970 in Crossfire  Sapphire NITRO R9-Fury in Crossfire *NONE*
  • Thermaltake Frio w/ Cooler Master JetFlo's in push-pull
  • Samsung 850 EVO 500GB SSD + Kingston V300 120GB SSD + WD Caviar Black 1TB HDD
  • Corsair TX850 (ver.1)
  • Cooler Master HAF 932
also, theres no signal when i plug the video cable into the bottom card, top one works fine
I dont have the button in pic 4
Check GPU-Z to see if Crossfire is enabled by default....
When in Crossfire, only the primary card's (top card) display outputs function.
AMD Ryzen Rig
  • AMD R7-5800X
so im all set?
the bottom card has no output
gpu-z detects 2 cards
so does msi afterburner
Edited by Bajantechnician
Only in games that support Crossfire, and I never found one. But others have told me they're out there so good luck. :D
gta v?
