PCI card wifi can't find wifi
Steven1997
Hello,
I have recently taken my netbook apart to find out the possible places where I could upgrade on it while putting it back together I encountered a problem I lost a screw what held the hinge and made it stable it is close to the pci area and I think that me having not found the screw could have been the problem what could easily be resolved by me getting one a putting it in at times when I'm near a router like next to it I can pick up the access point I did use a wifi usb adapter and it stopped working I brought another and encountered the same problem
There shouldn't be any drive compatibility issues as I'm running ubuntu 15.10 and it recognise the pci adapter
Thanks
Steven
Hello,
Thanks
Steven
just replace the screw...
If you need remote help fixing something on your computer
I can help over Teamviewer if you wish
just msg me on my profile
So will that fix it because I don't want to go into all the trouble of taking it apart as it is a netbook
it should
its probably just loose cause theres nothing holding it down
could even use a drop of superglue
it should
Ahh alright or I might just take it to my pc repair shop as I am paying month for support and that I need need some help because I need it fixed asap but now I know thanks for your help :)
