HOW DO I ADD A FAN
WebPlayz
HI i have the antec nsk4100 and i want to add a fan in the front but idk how to pop the front off to hook it up! please help! THX
CPU: Intel Core i9 9900K | Ram: 16GB Corsair LPX 3000 DDR4 | Asus Maximus XI Hero Z390 | GPU: EVGA RTX2080 XC | 960 EVO Samsung 500GB M.2 | 850 EVO Samsung 250GB M.2 | Samsung 1TB QVO SSD | 1TB HDD WD Blue
Laptop: Dell XPS 13 2 in 1 9370 | I7 1065G7 | 32GB DDR4 | 1TB SSD |
With your case you can't pop the front panel off, if you open it up inside at the front there are two fan mounts, there might already be fans there. Just unscrew them with a philips head screwdriver and replace it with your new one. Then trace where the fan cable is connected to the motherboard and unplug it by using a little bit of force and then replace it with the cable on your new fan. Hope this helped :D
CPU: Intel i7-4790k | Cooler: Corsair H110i GT | Motherboard: MSI Z97I AC  | Graphics Card: SAPPHIRE R9 280  | http://uk.pcpartpicker.com/p/pszsdC
http://adamredfern.co.uk
http://rewinded.co.uk
http://yewtreeservices.co.uk/
http://asiat.co.uk/
http://ssstelecom.co.uk
http://hndrx.co.uk/
http://wisemove4u.com/
By not using caps in the title.
Usually there are screws in the front, unscrew them and you should be able to pull off the front panel off.
my case has only one fan mount and has none and i can't just pull it off and no screws are there
Can you attach some pictures?
http://asiat.co.uk/
http://hndrx.co.uk/
sure let me try to get a photo
post-285612-0-37152300-1450987964_thumb.
theres where the fan goes but i don't know where the thing is to remove front pannal
