MY AUDIO AND MIC DOESN'T WORK! PLZ HELP
Hey i just built my first ever custom pc, and when i tried plugging my earphones into my audio jack it doesnt work. I plugged in my blue snowball into the mic jack and it doesnt work either so plz help me!!!
SPECS:
amd fx 8320
windforce gtx 960 4gb
16 gb of ddr3 ram
Audio drivers? Plugged in front panel audio to MOBO? Configured audio in Control Panel?
Intel Core i7-6700K | Corsair H105 | Asus Z170I PRO GAMING | G.Skill TridentZ Series 16GB | 950 PRO 512GB M.2
Asus GeForce GTX 980 Ti 6GB STRIX OC | BitFenix Prodigy (Black/Red) | XFX PRO Black Edition 850W
My BuildPCPartPicker | CoC
Do you have the audio drivers installed?
They can be located on the CD Disk provided with your MoBo.
yup I installed everything
Where are you plugging in the aux cables?
In that case, are the front case umbilicals fully installed in the correct place?
Dumb question, but did you plug all the things in correctly? E.g. green for audio/sound and red for microphone?
Quote
Fanboys, on both sides, are quite embarrassing. How can one be a "fan" of a company? A companies only goal is to make a profit off you. Instead of being a smart consumer and base your purchase decision on the best price / performance you choose to dick yourself over by only considering brand X. Idiotic loss to be honest.
~Quibiss
I think the Blue Snowball can't be plugged into the mic jack because it's a USB microphone.
It's driverless.
