Need help with overclocking R7 370 2GB Gaming edition
alanp97
Are there any references to this card being overclocked that i can compare voltages and clock speeds etc? So far i can`t seem to find much. I have good cooling and would like to overclock to see if i can get some extra fps. Should i use msi afterburner or the motherboards interface for doing it or what should i do ? Any tips whatsoever will be appreciated! Thanks in advance.
How do you use the motherboard's interface for overclocking a card?
I'd just use Afterburner.
Just turn the things up and make sure it doesn't get too hot or crash! More voltage means more stable at higher clocks but more heat and a hotter card.
Sig under construction.
Test using Unigine heaven @Max tesselation
I3-4150 | Be Quiet! Dark Rock Pro 3 | 8GB KINGSTON FURY RAM | MSI Z97-G43 | HYPERX FURY 120GB SSD SAPPHIRE HD7950 VAPOR-X | Phanteks Enthoo Pro M | EVGA 500W | Corsair SP120's w/ NZXT Fan Hub
Plans: I5-4690K || EVGA GS 650W | KINGSTON FURY 8GB RAM  PCPARTPICKER: https://uk.pcpartpicker.com/
