A few questions about CPU/MoBo/CPU Cooling
Solved by Imakuni,
Thanks, I had a feeling I needed a new mobo, any suggestions that would work fine with this chip, i hear gigabyte had some issues with it?
Pick one you like: http://pcpartpicker.com/parts/motherboard/#c=99&sort=a8&page=1
Also I did one single "test" since I got it (because I didnt have time to carry any other real tests). I saw that while in cs:go, my cpu goes up to 40% and 50-60 degrees celsius, is this normal? in idle I get 35-40.
Yeah. It's more than fine.
