Fan connector trouble
I am going to install 5 AF140's into my mATX case, (don't ask how that works), but I want them to not run at max load. Is there a fan controller that lets me connect all 6 fans in my case to the power supply but control it with the motherboard header?
Well, you can just use splitters.
It's neater to use something like an NZXT GRID though.
If you want more granular software control then look no further than the NZXT GRID +
Don't do this!!!!
If it was a molex connector, this would be fine, but NOT with a motherboard fan header. I'd recommend maximum 2 fans running from your motherboard header with a splitter. Motherboard traces are not designed to be carrying several amps of current for a prolonged period of time. 2 fans is fine because the motherboard traces only have to carry around a peak of 2A to get the fans moving (newer fans are more efficient btw, using much less current when started), however 5 fans is just asking for trouble.
OP should use a Molex splitter that allows for PWM fan control or use either version of the NZXT GRID that you suggested.
Speedtests
WiFi - 7ms, 22Mb down, 10Mb up
Ethernet - 6ms, 47.5Mb down, 9.7Mb up
Rigs
 Type            Desktop
 OS              Windows 10 Pro
 CPU             i5-4430S
 RAM             8GB CORSAIR XMS3 (2x4gb)
 Cooler          LC Power LC-CC-97 65W
 Motherboard     ASUS H81M-PLUS
 GPU             GeForce GTX 1060
 Storage         120GB Sandisk SSD (boot), 750GB Seagate 2.5" (storage), 500GB Seagate 2.5" SSHD (cache)
Type            Server
OS              Ubuntu 14.04 LTS
CPU             Core 2 Duo E6320
RAM             2GB Non-ECC
Motherboard     ASUS P5VD2-MX SE
Storage         RAID 1: 250GB WD Blue and Seagate Barracuda
Uses            Webserver, NAS, Mediaserver, Database Server
Quotes of Fame
On 8/27/2015 at 10:09 AM, Drixen said:
Linus is light years ahead a lot of other YouTubers, he isn't just an average YouTuber.. he's legitimately, legit.
On 10/11/2015 at 11:36 AM, Geralt said:
When something is worth doing, it's worth overdoing.
On 6/22/2016 at 10:05 AM, trag1c said:
It's completely blown out of proportion. Also if you're the least bit worried about data gathering then you should go live in a cave a 1000Km from the nearest establishment simply because every device and every entity gathers information these days. In the current era privacy is just fallacy and nothing more.
Don't do this!!!!
You'd hope they weren't using just one header. You're assuming that he is an eejit.
If you want you can use your motherboard fan headers to control the fans depending on the motherboard, but for 3 pin fans the NZXT Grid+ V2 is good for indivudally controlling fans.
smile.png R.I.P. Motherboard if he used one header. If his mobo has 3 fan headers incl. CPU connector, he's fine getting a few splitters and running 2 fans from each one. Cable management would be fugly though (*cough*likemineisanybetter*cough*) so he's probably better off with the NZXT GRID.
Speedtests
Rigs
 Type            Desktop
 OS              Windows 10 Pro
 CPU             i5-4430S
Type            Server
OS              Ubuntu 14.04 LTS
RAM             2GB Non-ECC
Quotes of Fame
