Sound issue - VERY Quiet voices / Everything else okay
DocShay
So awhile ago I noticed, once in awhile when playing video files the voices were non-existent, or very barely audible.
Uninstalled VLC, Uninstalled Realtek Audio Driver - Reinstall - Boom fixed.
Now, on and off this kept happening. Today, I did the normal (above mentioned) - and to my surprise - It did not fix it.
I notice this only appears to happen with high definition video files - standard XVIDS and non-HD files play as per normal.
running out of ideas on something to try, any suggestions?
what are your headphones? seems like an issue with mid frequencies
RIG #14670k @4.4 / 1.25v vcore. @ 4.5 / 1.3v vcore/ 1.95v vccin. MSI GAMING 4G GTX 970 @1540/3700 1.275v BIOS MOD. 16GB Kingston HyperX Savage RAM 2400mhz. MSI GAMING 5 Z97 MOBOFractal Design Define S. Dark Rock Pro 3. 850 EVO 250GB Seasonic M12II 620w
RIG #2: 4790k @ 4.6 / 1.25v vcore. EVGA SC ACX 2.0 980 SLI16GB Corsair Vengeance Pro 2400mhz. Asus MAXIMUS VII Hero Z97. Fractal Design Define R5. NH D15. 850 EVO 250GB AX 860
Are you plugging your headphones into the audio jack on the motherboard or the front panel connector audio jack? My front panel audio jack gives much more sound than my motherboard audio jack.
More info: This is for my regular stereo speakers, not headphones. Using the standard  plug on the mobo side.
My USB headphones work just dandy.
