Point of view
Funergy
Go to solution Solved by jimakos234,
http://www.samsung.com/be/consumer/pc-peripherals-printer/monitor/monitors/LS27D590PSX/EN
But I have 3 questions.
this one is the 5-series and has a Mega ∞ contrast ratio and the 3-series has a Mega DCR contrast ratio. What is the difference?
and the second question is, on all the monitors pages I see windows certificate like Windows 8.1 and Windows 10.
Does it change anything????
Is this one superior to this one http://www.samsung.com/be/consumer/pc-peripherals-printer/monitor/monitors/LS27E390HS/EN ?
i am no expert at monitors man,i would say to make a topic about what monitor you should buy and location etc, so people that really know about monitors can really help you.
Hello,
I just want you guys' point of view about my build I'm planning.
http://pcpartpicker.com/p/PDY3Lk
Its for using Adobe products like Photoshop and After Effects.
I also plan on playing games on it. I know my monitor isn't made for competitive gaming but I dont care about that fact.
- Funergy
PSU is low quality, go here: http://linustechtips.com/main/topic/406160-psu-ranking-and-tiers/ and pick from Tiers 1 or 2.
Other systems I've built:
Hello,
- Funergy
Get a hyper 212 Evo for your CPU Cooler
Get a 250 GB Samsung 850 Evo: it costs less for more.
Get a better PSU
Get an R9 380
EDIT: Your build needs more Evo xD
LIBERATOR: Core i5 6400 @ 2.7GHz | GeForce GTX 670 2 GB | HyperX Fury 8GB DDR4 @ 2133 MHz | 250 GB Samsung 850 Evo SSD
My new build; Liberator, Check it out
The more friendly we are, the more helpful we are!
MY OLD BUILD (AKA PREBUILT MONSTROSITY)
INSANITY: AMD Athlon II X2 @ 3.0 GHz | Geforce GT 720 2 GB | 4 GB DDR3 @ 1333 MHz | 120 GB Silicon Power SSD | 500 GB Hitachi HDD
Hello,
- Funergy
I would get a I7 6700k and a evga supernova 650w GS
PC Specs:
Core I5 4690K CPU
Gigabyte GTX 960 windforce 4GB GDDR5 GPU
Corsair 100R case
Seasonic 620W S12-II PSU
Kingston SSDNow 120GB SSD
Toshiba 1TB HDD
Asrock H97 Pro4 motherboard
8GB panram DDR3 1600 RAM
Windows 10 home 64 bit
I don't really plan on overclocking since the stock is already good enough for me and I already know the risks for overclocking.
Get a better PSU
Get an R9 380
Since you guys say its a bad PSU I'll take another one. How much Watt should I choose 550W Or 650W
And where I'm buying the pc parts (Belgium) the 250GB(99 euros) one costs ±30 euros more than the 120GB(69 euros) one.
And I'm using adobe products and after effects for the 3D rendering too and there its all 'bout da cudas (I think last I checked.)
In that case, the 960 is better for you. Happy building
Would I rather take a 550W PSU or a 650W?
Hello,
- Funergy
Get this :
PCPartPicker part list: http://pcpartpicker.com/p/W9K6GX
Price breakdown by merchant: http://pcpartpicker.com/p/W9K6GX/by_merchant/
CPU: Intel Core i7-5820K 3.3GHz 6-Core Processor ($319.99 @ Micro Center)
CPU Cooler: Corsair H100i GTX 70.7 CFM Liquid CPU Cooler ($99.99 @ Micro Center)
Motherboard: MSI X99S SLI Krait ATX LGA2011-3 Motherboard ($179.99 @ Newegg)
Memory: G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-2400 Memory ($74.99 @ Newegg)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive ($77.88 @ OutletPC)
Storage: Seagate Barracuda 3TB 3.5" 7200RPM Internal Hard Drive ($82.89 @ OutletPC)
Video Card: MSI Radeon R9 390X 8GB Video Card ($374.99 @ Micro Center)
Case: NZXT S340 (Black) ATX Mid Tower Case ($59.99 @ Micro Center)
Power Supply: SeaSonic X Series 850W 80+ Gold Certified Fully-Modular ATX Power Supply ($89.99 @ Newegg)
Monitor: Dell E2414HM 60Hz 24.0" Monitor ($99.99 @ Best Buy)
Total: $1460.69
Generated by PCPartPicker 2015-12-22 10:25 EST-0500
You can buy a windows license for cheap off g2a or reddit
Edit, if you need cuda get a 970
AMD Ryzen R7 1700 (3.8ghz) w/ NH-D14, EVGA RTX 2080 XC (stock), 4*4GB DDR4 3000MT/s RAM, Gigabyte AB350-Gaming-3 MB, CX750M PSU, 1.5TB SDD + 7TB HDD, Phanteks enthoo pro case
If you gotsa go with the cudas, the 550 will be enough. Should handle a minor gpu upgrade as well some point into the future. Make sure the psu is from antec, seasonic, xfx, or superflower.
I chose one from Corsair (RM650) from the tier 2 category, is there a problem with these?
Shouldn't be as far as I know.
get a 980/970 if you need cuda
CPU: Intel Xeon E3-1231 V3 3.4GHz Quad-Core Processor  ($242.99 @ SuperBiiz)
CPU Cooler: be quiet! PURE ROCK 51.4 CFM Sleeve Bearing CPU Cooler  ($28.99 @ NCIX US)
Motherboard: MSI H97 PC MATE ATX LGA1150 Motherboard  ($88.75 @ OutletPC)
Memory: Corsair Vengeance 16GB (2 x 8GB) DDR3-1600 Memory  ($69.99 @ Amazon)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($49.98 @ OutletPC)
Video Card: Sapphire Radeon R9 390X 8GB Tri-X OC Video Card  ($413.98 @ Newegg)
Case: NZXT H440 (Matte Black) ATX Mid Tower Case  ($109.99 @ Newegg)
Power Supply: EVGA SuperNOVA GS 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($89.98 @ Mac Mall)
Operating System: Microsoft Windows 10 Home OEM (64-bit)  ($92.99 @ NCIX US)
Monitor: Asus MX239H 23.0" Monitor  ($173.99 @ SuperBiiz)
Total: $1439.51
Generated by PCPartPicker 2015-12-22 11:59 EST-0500
The site has changed....
Total: $1439.51
Get this :
Total: $1460.69
I dont need you to make my PC I ask you to share your opinion about my PC I built.
you can do really better in that price range, for example you can get better psu/gpu/ssd
Not in my case. I will buy it in Belgium and there my build costs 1800 euros in total with monitor.
Thats the cheapest I can get it.
where are you buying from belgium? amazon, other cross-europe eshops like caseking.de mindfactory.de or other local stores?
you can still improve your build imo.
Alternate Belgium
Alternate Belgium
You can get even better psu, also pick one of the 2gpus provided. or a get a 390x
finally check if  the  cpu cooler fits in  the case
post-248090-0-25377100-1450812112.pngpost-248090-0-82698800-1450812139_thumb.
I'm fine with you saying I should get and AMD graphics card. But I plan on using Aftereffects ray tracing which needs the cuda cores. I can also use ray tracing via the CPU.
If I can get more FPS for less money by buying an AMD graphics card I would definitely buy an AMD card. But would getting a better CPU like the new Skylake series be better if using an AMD card then? Its not like I use ray tracing the whole time because its only 2/10 what I want to do on the PC. Is it worth-it? Give me some advice.
if cuda is a must ,go for a gtx 970/980, it should be more than enough,they are great cards for sure
but technically, to answer the question, for the time being, AMD cards have a better price/performance ratio than the current Nvidia lineup.
cpu-wise, when comparing skylake with haswell-refresh, the difference is not that noticable, and they both work great paired with AMD/Nvidia gpu
How is this then?
https://pcpartpicker.com/parts/partlist/
Its at the same price. I don't need an overpriced motherboard. and with this I can get a MSI GTX 970
