Reference 980 TI
- 1000 MHz Base Clock
- 1075 MHz Boost Clock
EVGA 980 TI Classified
- 1190 MHz Base Clock (stock) 190 MHz overclock respectively when compared to the reference design
- 1291 MHz Boost Clock (stock) 216 MHz overclock respectively when compared to the reference design
During my stock testing, the actual boost clock held steady at 1392 Mhz.
Overstock: Core clock +58 Mhz (1450 MHz Boost Clock) 375 MHz overclock respectively when compared to the reference design
+104 Memory Clock (1805 Mhz)
Good core clock, memory is a bit lacking though.
12600k | MSI MEG S280 | SSUPD Meshilicious | Asus ROG STRIX Z690-I | Crucial 16GB 4800MHz CL38 | MSI Gaming 980Ti | CM V850 SFX | WD SN850 1TB, WD SN550 1TB
Pi 4TB NAS | Asus VG27AQ, Asus PB278Q | Logitech G Pro X Superlight | Glorious G-HXL-STEALTH | Keychron K4 V2 | Sennheiser HD 599 w/ Fiio E10
I'll play with the card. I could push it further to +350 at least, instead of 104 I believe.
Oh wow just saw you were running at +50mV, is your card stable at those settings?
Yes why, should I keep it at +0? I want a stable OC so I don't mind adding a little more voltage.
I've got mine at +0 mV, 1471MHz Core and 1977MHz memory stable, but can push 1524MHz core and 2000MHz memory - I'll have to see if I can keep that stable.
