galaxy s4 battery life
ilyas001
hi guys a have a big issue with my battery life for my galaxy s4 i don't get it the battery drains fast very fast it takes less then 2 hours of normale use to get the battery at low and takes alot more to get charged fully like 6 hours i don't get it because i used tool like antutu tester and my battery life is normale compared to other phones so i'm i just hallucinating or does the phone really have a probleme
Batteries age, probably a dying battery.
Could be junk on your phone sapping the battery power. Could be old dying battery.
Get a replacement battery, flash to stock android ROM, give it a dark or pitch black background. Apps like Greenify also help.
it was the same thing from the start i always had that probleme of battery with original rom or the new one
