Starting Youtube Channel...looking for 1080p editing and rendering PC spec
joongpark
I am starting a toy youtube channel (I own a toy store).
I am only going to start with 1080p video until I get really good at it.
What kind of spec do I need for rendering 1080p?
I already have following parts.
i7-4790K
32GB HyperX RAM
MSI gaming 5 Mother Board
Corsair 800w modular Power
only thing I can't decide is following
- 1 X GTX 970 (possible add another 970 when I go to 4k)
- 2 X GTX 980 SLI
- 1 X GTX 980
Thanks for any suggestions.
Kevin.
i7-4790K
32GB HyperX RAM
- 2 X GTX 980 SLI
- 1 X GTX 980
Kevin.
Plz tell me it's not a CX series...... (PSU) They're cancer.
CX is perfectly fine for low end systems.
QUOTE ME IN A REPLY SO I CAN SEE THE NOTIFICATION!
When there is no danger of failure there is no pleasure in success.
Sorry...I checked and this is PW I have.
Cooler Master Silent Pro 700W
Take any PSU of one of the higher tiers of the following list:
http://linustechtips.com/main/topic/406160-psu-ranking-and-tiers/
600W should be enough, but you might want to take 700W if you're gonna add another gpu later. I recommend a single 980 though.
But this is not a low end build!
|| Asrock Z68 Extreme 3 Gen 3 || i5 3570 @3.5GHz || Zalman CNPS10X Optima || 8GB RAM HyperX Fury Blue @ 1600MHz || Thermaltake Berlin 630W || Zalman Z11 || Gainward Phantom GTX 970 || 120GB Kingston V300  (Gift) + 1TB  WD Green
Phone: Xiaomi Redmi Note 8
Tablet: iPad Mini 2
I am more concerned about GPU than PSU as PSU can be upgraded easily but GPU is more perminant (because I might do SLI later)
Thanks for any suggestions on GPU.
Kevin.
Yes but calling it cancer means it's bad no matter what, which it isn't.
