My PC build so far, wondering if I can improve it and what cables to get
Marsquakes
Graphics Card
£97.98 EVGA GTX 750 Ti Dual Fan ACX 2 GB
CPU
£82.99 AMD FX6300 Black Edition 6 Core
RAM
£19.82 DELL 8GB (2X4GB) PC2-5300
Hard Drive
£39.99 WD Green 1TB
Optical Drive
£12.98 Samsung SH-224FB 24x DVD Re-Writer
Motherboard
£55.98 Asus M5A97 LE R2.0 Motherboard
Power Supply
£36.99 Corsair Builder Series CX 430 Watt ATX/EPS
Case
£30.48 Thermaltake Versa H15 M-ATX Gaming Case
Wireless Adapter
£9.50    Zyxel Wireless PCI Adapter
Mouse + Keyboard
£9.99    Gaming Bundle - Keyboard + Mouse
Operating System
£19.55 Windows 7 Home Premium
Monitor
£69.99  AOC e2070Swn 19.5" LED Monitor
1 x VGA Cable
£3.49    Gold Plated Copper Core VGA 15pin
Total: £489.73
xD
Graphics Card
CPU
RAM
Hard Drive
£39.99 WD Green 1TB
Optical Drive
Motherboard
Power Supply
Case
Wireless Adapter
Mouse + Keyboard
Operating System
Monitor
1 x VGA Cable
Total: £489.73
Please don't get the FX 6300...
I'll be back with a build
*EDIT* BUILD!
http://uk.pcpartpicker.com/p/GkZN8d
Add your 20 Pound Windows 7 license and a 5 dollar HDMI cable and other accessories and you're good to go!
Fine you want the PSU tier list? Have the PSU tier list: https://linustechtips.com/main/topic/1116640-psu-tier-list-40-rev-103/
Stille (Desktop)
Ryzen 9 3900XT@4.5Ghz - Cryorig H7 Ultimate - 16GB Vengeance LPX 3000Mhz- MSI RTX 3080 Ti Ventus 3x OC - SanDisk Plus 480GB - Crucial MX500 500GB - Intel 660P 1TB SSD - (2x) WD Red 2TB - EVGA G3 650w - Corsair 760T
Evoo Gaming 15"
i7-9750H - 16GB DDR4 - GTX 1660Ti - 480GB SSD M.2 - 1TB 2.5" BX500 SSD
VM + NAS Server (ProxMox 6.3)
1x Xeon E5-2690 v2  - 92GB ECC DDR3 - Quadro 4000 - Dell H310 HBA (Flashed with IT firmware) -500GB Crucial MX500 (Proxmox Host) Kingston 128GB SSD (FreeNAS dev/ID passthrough) - 8x4TB Toshiba N300 HDD
Toys: Ender 3 Pro, Oculus Rift CV1, Oculus Quest 2, about half a dozen raspberry Pis (2b to 4), Arduino Uno, Arduino Mega, Arduino nano (x3), Arduino nano pro, Atomic Pi.
Graphics Card
CPU
RAM
Hard Drive
£39.99 WD Green 1TB
Optical Drive
Motherboard
Power Supply
Case
Wireless Adapter
Mouse + Keyboard
Operating System
Monitor
1 x VGA Cable
Total: £489.73
Maybe change change the vga cable to a dvi cable and change the ram to something like corsair or Kingston.
Looks pretty bad tbh,
Wouldn't recommend the FX6300 use an i3 and a H81 board.
The RAM is OKish like itll do the job and is good for the price.
Sadly no SSD which is a bit of a bitch because if you get one you'll have to reinstall windows.
The case looks pretty cheap and nasty and i can only assume the keyboard + mouse combo is the same considering its a tenner.
The PSU is also not of the best quality and is pretty meh, its built for handling office sytems/uses.
I3-4150 | Be Quiet! Dark Rock Pro 3 | 8GB KINGSTON FURY RAM | MSI Z97-G43 | HYPERX FURY 120GB SSD SAPPHIRE HD7950 VAPOR-X | Phanteks Enthoo Pro M | EVGA 500W | Corsair SP120's w/ NZXT Fan Hub
Plans: I5-4690K || EVGA GS 650W | KINGSTON FURY 8GB RAM  PCPARTPICKER: https://uk.pcpartpicker.com/
Think I should use a worse graphics card in trade for a better CPU. I do prefer hard drives for more space.  I'm not looking for a good mouse and keyboard, just want to get a working PC off the bat. That case, I'll look into. Thanks for the info Doge (never thought I'd be saying that.). Going to be looking for another PSU asap.
xD
Build above.
Stille (Desktop)
Evoo Gaming 15"
