A Case For My Case
A Friendly N00b
Hello!
The current case I'm using is the NZXT S340.
I'm going to be moving it soon, but I want to move it safely, with as little disruption to it as possible.
I've seen some "Desktop Travel Cases" and "Desktop Transport Cases" around, but most of them are expensive, and I don't know if my case will fit inside of them.
Does anyone know of a transport/travel case that is fairly inexpensive, and can contain the NZXT S340 case?
edit: saw the repeated, deleted it
Buy Another S340 Take its box, put yours in it. Return the other S340. Then. Profit
"In the middle of every difficulty lies opportunity."
- Albert Einstein
you can ask the support for an box for the case since i have heard that the support from nzxt is really good
Specs: CPU: I5 6600K (4.5 GHZ), GPU: RX 480 (stock), Mobo: MSI Z170A tomahawk AC, RAM: Corsair 16GB drr4 2600, CASE: NZXT S340, storage 240GB crusial SSD and a 1TB WD HHD
