personally Id use new fluid if possible.  Even distilled until you could add in concentrate (within a week or two at most)
I am changing cases from a Fractal Design R5 to a corsair 750D. I have new tubing. There is no official drain system currently in the system. How should I transfer the water cooling without losing any fluid (if possible)?
sorry or did you mean how should you drain it without spilling all over your pc?
LTT Community Standards                                               Welcome!-A quick guide for new members to LTT
Man's Machine- i7-7700k@5.0GHz / Asus M8H / GTX 1080Ti / 4x4gb Gskill 3000 CL15  / Custom loop / 240gb Intel SSD / 3tb HDD / Corsair RM1000x / Dell S2716DG
The Lady's Rig- G3258@4.4GHz(1.39v) on Hyper 212 / Gigabyte GA-B85M / gtx750 / 8gb PNY xlr8 / 500gb seagate HDD / CS 450M / Asus PB277Q
https://linustechtips.com/topic/509318-how-to-drain/#findComment-6792396
Without it spilling
do you have a picture?  I've always had an extra port I can rotate to point out of my case and tilt the case over a container.  can you remove the cpu block from the board and move it away from the pc at all?
https://linustechtips.com/topic/509318-how-to-drain/#findComment-6792474
I´d go and drain the current loop at its lowest point and reinstall all components new. It isn´t worth the hassle to try to put a custom loop into a new case. Regarding you need to mount a mainboard, PSU, etc. I´d do it step by step and then you know it´s done right.
Intel i7 7820X (delidded) @ 4.9GHz - MSI X299 M7 ACK + EKWB Fullcover Block - G.Skill Trident Z 32GB @ 3466MHz - nVidia Titan Xp + EKWB Fullcover Block @ 2.1GHz - Samsung 960Pro 2x - WDD Blue 2TB - Seasonic 750W Platinum - modded Corsair 600C - Hardtubed Custom Watercooling
https://linustechtips.com/topic/509318-how-to-drain/#findComment-6792990
That's not what he's asking. He wants to know how to drain his system that doesn't have a drain port at the lowest point. I'd also advise against opening up the loop at the lowest point because all the water will do what he's trying to avoid, gush out and splash/spill everywhere.
Without it spilling
Post a picture of your system please to show us where all your fill ports and connections are. Before mounting my 240mm rad to the front of my case I used to take out my GPU etc and put a jug on my psu then undo one of my fittings and let the coolant flow into the jug.
Chernobyl
AMD FX8350 @ 5GHz | Asus Sabretooth 990FX R2 | 16GB HyperX Savage @1950mhz CL9 | 120GB Kingston SSDNow
EK AMD LTX CSQ | XSPC D5 Dual Bay | Alphacool NexXxoS XT45 240mm & Coolgate Triple HD360
Kraken
Intel i5 4670K Bare Die 4.9GHz | ASUS Maximus VII Ranger Z97 | 16GB HyperX Savage 2400MHz | Samsung EVO 250GB
EK Supremecy EVO & EK-MOSFET M7G  | Dual 360mm Rads | Primochill CTR Phase II w/D5 | MSI GTX970 1670MHz/8000MHz
Graphic Design Student & Overall Nerd
https://linustechtips.com/topic/509318-how-to-drain/#findComment-6795459
if you have a tube res or a pump with more then 2 G1/4 's . picture of your rig would help for telling you how to insert/ drain it
for the tube res way attach a long piece of tubing to the top of the res and then lay the case down . then put the tubing into the bucket the other end then flip the case upside down so top is bottom and bottom is now the top and it should drain slowly. then once you got all you can work your way down dissableing the loop and if you got something to suck fluid out of your res makes it much quicker .
for the pump way mostly the same  but a bit different lay it down on the back . and with alot of paper towels unscrew the extra port on your pump  and attach another tube then stand the case back up and either unscrew the res cap , or a fitting  a tiny bit and it should drain mostly . i did number 2 when i moved my loop into my 750d . its  a pain but always put something to drain or fill since its much easier then . i would show you what i have but my loop is in pile atm moving my rads external so its a mess
this is what i used 3 rotary 90's and a 60mm extension fitting with a plug . give me enought time to screw on the tube or just stick a bowl or a bucket under the flow once i undo res fitting
for the fluid i have done it but  i use pre mix so i can get away with it sometimes . for distilled just get more same with the bioside needed .
main rig
 corsair 750d | evga 1000w g2 | Gigabyte x99 soc champ | 5820k 4.0GHz | 1tb wd blue | 250gb samsung 840 evo  | Crucial Ballistix Sport XT 16GB 8x2 DDR4-2400 | MSI GTX 970 x2 | monitor Acer B286HK 28" 4K | razor chroma blackwidow  | razor death adder chroma
CENTOS 7 SERVER (PLEX&docker stuff)
NZXT s220 | evga 500w 80+ | AMD FX 8320e | ASUS M5A78L-M/USB3 | 2x8gb non ecc ddr3 WD red 2TBx2 | seagate 160gb microcenter 8gb flashdrive OS
https://linustechtips.com/topic/509318-how-to-drain/#findComment-6796051
That is strongly depending on the case it self. When you have cases like bigger Caselabs or a Corsair 900D full with radiators. Then I´d strongly advice to open the loop at a very low point. You won´t be able to wiggle and lift the case around easily... they´re just too bulky and heavy. I agree if it is a small case the he could open the loop on the back side of the GPU.
It is always a safe plan in the future to also install a draining system.
https://linustechtips.com/topic/509318-how-to-drain/#findComment-6797600
I did assume that the OP has a mid tower as most people don't buy caselabs or corsair 900D towers without installing a drain due to your reasoning...
That and he also states the current loop is in an Fractal Design R5 swapping to a 750D.
Chernobyl
Kraken
https://linustechtips.com/topic/509318-how-to-drain/#findComment-6797609
Yeah with my 900D the drainport was a must have as long as I used to internal radiators. If he´s got a mid tower he could try to get away with opening the loop on a higher spot where he can reach and work safely and just turn the case upside down. You are right.
https://linustechtips.com/topic/509318-how-to-drain/#findComment-6797626
I know, cos I just take the port off my front rad, catch the first coolant with a paper towel wad, then screw in a fitting with a bit of tubing and tip it after undoing the res fill port.  :D
It isn't Ideal but when I switch to hardline I'll get a valve fitted.
Chernobyl
Kraken
https://linustechtips.com/topic/509318-how-to-drain/#findComment-6797652
Haha I´m way lazier than you :D. With my build I´ve got an external radiator draining my loop is a joke hehe. But I also ditched the 900D for the new Corsair 600C unfortunately I can´t finish it right now because I´m 5000 miles away on vacation lol...
https://linustechtips.com/topic/509318-how-to-drain/#findComment-6797674
Haha! I used to also have an external 120mm rad which made life a lot easier but it looked ghetto as all hell. I'm not lazy just couldn't afford to fit a drain port till after xmas.
Chernobyl
Kraken
https://linustechtips.com/topic/509318-how-to-drain/#findComment-6798665
