Old power supply compatible with new pc?
Drunkaroos
Go to solution Solved by STRMfrmXMN,
Hi all. My power supply failed a few days ago(terrible Thermaltake TR2 600w), and right now I am using a borrowed power supply. To replace the borrowed one I have a last gen Corsair HX 650w 80+ gold. My specs are in my signature, will the Corsair psu work with my system?
You're more than OK, my friend.
Tokyo Sunshine:Corsair 750d case with custom lighting, Asus ROG Maximus VIII Z170, Intel i5-6600 processor, 16gb HyperX Fury DDR4 RAM, MSI r9 270x 4gb@ 1300mhz mem clock, Sandisk Ultra II SSD 256gb, 2x 1tb HDD
Yeah it will. I don't see why it won't work with the system.
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
Yep :)
Mines great, is truly a good quality unit :D
Yes, your build only used like 350 watts.
|PSU Tier List /80 Plus Efficiency| PSU stuff if you need it.
My system: PCPartPicker || For Corsair support tag @Corsair Josephor @Corsair Nick || My 5MT Legacy GT Wagon ||
