how long can a display port be without adding any input lag?
Cvdasfg
Go to solution Solved by Alphinon,
How long can a display port cable get before adding any type of delays or differences?
TX10 Build Log: http://linustechtips.com/main/topic/456229-tx10-build-log/
Case: TX10-D   Proccessor: i7-5820k   MotherBoard: Asrockx99 Extreme4   Ram: Crucial Ballistix Sport 16GB (DDR4-2400)   GPU: Asus Strix OC 980ti   Storage: 850pro 500gb, 850pro 500gb, 850pro 256gb, WD black 16tb total, Silicon Power S60 120GB   PSU: Seasonic snow silent 1050   Monitors: Three of Asus VG248QE 144Hz 24.0"
The above answer is correct.
The answer for other cable types is that you'll degrade the signal too far to want to look at it before there is an induced time lag. One nanosecond (0.000 000 000 1 sec) is 11.8 inches long. By the time you're off by 1/1000th of a second you're looking at wires over 186 miles long!
Good video on that with Grace Hopper in this link: http://highscalability.com/blog/2012/3/1/grace-hopper-to-programmers-mind-your-nanoseconds.html
Thanks! Any suggestions on cable?
