My first PC Build any suggestions?
Gokhantur
Hi guys,i'm building my first pc and if you guys give me your opinions that would be great thanks.
Main usage of the pc will be gaming like AAA games and i hope to get 60+ fps in Ultimate settings,1080p with this build.
Pcpartpicker link : http://pcpartpicker.com/p/CHNbmG
CPU Cooler: CRYORIG H7 49.0 CFM CPU Cooler  ($32.50 @ Newegg)
Motherboard: Asus Z170-A ATX LGA1151 Motherboard  ($153.99 @ SuperBiiz)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($77.88 @ OutletPC)
Video Card: MSI Radeon R9 390 8GB Video Card  ($329.98 @ SuperBiiz)
Case: Corsair 200R ATX Mid Tower Case  ($57.99 @ Micro Center)
Monitor: Asus VG248QE 144Hz 24.0" Monitor  ($239.99 @ Micro Center)
Total: $1307.35
Generated by PCPartPicker 2015-12-18 21:54 EST-0500
Better cooler, better GPU, you're all set!
i5-4690k@4.5GHz || MSI GTX 970 || MSI z97 Gaming 5 || NZXT Kraken x61 || WD Black 1TB || Crucial MX100 || 8GB Corsair Vengeance Pro || Corsair RM750 || NZXT H440 || Corsair k70 RGB mx browns || Acer H236HL || ViewSonic VX2255wm-4
Looks good overall, however I feel that a more powerful graphics card would be advisable (980, 980ti, titan x, r9 390x, r9 fury, r9 fury x).
That cpu cooler is great, I have a i5 2500k running at 4.5ghz all day on the hyper 212 plus(the older/not as good version)
CPU has twice the threads, and it includes a much higher end 1440p 144hz free-sync display, that is sadly a TN panel
for 200 less you have a 1080p 144hz TN display, or a 21:9 1080p IPS free-sync display
it also has a larger SSD and a mass storage drive
PCPartPicker part list: http://pcpartpicker.com/p/kvbYvK
Price breakdown by merchant: http://pcpartpicker.com/p/kvbYvK/by_merchant/
CPU: Intel Xeon E3-1231 V3 3.4GHz Quad-Core Processor  ($242.99 @ SuperBiiz)
Motherboard: Asus H87M-E Micro ATX LGA1150 Motherboard  ($73.99 @ SuperBiiz)
Memory: Crucial 8GB (1 x 8GB) DDR3-1600 Memory  ($34.97 @ OutletPC)
Storage: A-Data Premier SP550 480GB 2.5" Solid State Drive  ($127.99 @ NCIX US)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($49.98 @ OutletPC)
Video Card: PowerColor Radeon R9 390 8GB PCS+ Video Card  ($298.99 @ SuperBiiz)
Case: Fractal Design Core 1000 USB 3.0 MicroATX Mid Tower Case  ($28.99 @ NCIX US)
Power Supply: Rosewill Hive 650W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($69.89 @ OutletPC)
Monitor: Acer XG270HU 144Hz 27.0" Monitor  ($453.99 @ Mac Mall)
Total: $1381.78
Generated by PCPartPicker 2015-12-19 00:36 EST-0500
Thank you guys so much for the replies.I haven't mentioned but i live in Austria(one without kangaroos :D),so the parts i have picked is the cheaper ones here.
For gpu i have pick gtx 970 because they say that nvidia has better optimisation for games and there is not much different between r9 390 and gtx 970 as far as fps goes.And im very confused about which one i should choose.For cooling im not planning on doing much overclocking so i think that one should do the job.And i got one last question `is skylake worth it or should i go with haswell and put the money to gpu?
Well the 390 is better overall due to it having relatively more performance, 125% more VRAM, potentially better DX12/vulkan support, but mostly you save money on free-sync vs G-sync
includes a 144hz 1080p free-sync display
PCPartPicker part list: http://de.pcpartpicker.com/p/G6VvBm
Price breakdown by merchant: http://de.pcpartpicker.com/p/G6VvBm/by_merchant/
CPU: Intel Xeon E3-1231 V3 3.4GHz Quad-Core Processor  (€274.88 @ Amazon Deutschland)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  (€35.50 @ Amazon Deutschland)
Motherboard: Asus H97M-E Micro ATX LGA1150 Motherboard  (€88.13 @ Amazon Deutschland)
Memory: Kingston HyperX Fury Blue 8GB (1 x 8GB) DDR3-1600 Memory  (€43.05 @ Amazon Deutschland)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  (€51.45 @ Amazon Deutschland)
Video Card: PowerColor Radeon R9 380 4GB PCS+ Video Card  (€217.53 @ Amazon Deutschland)
Case: Cooler Master N300 ATX Mid Tower Case  (€64.42 @ Amazon Deutschland)
Power Supply: Corsair CX 600W 80+ Bronze Certified Semi-Modular ATX Power Supply  (€79.90 @ Caseking)
Monitor: AOC G2460PF 144Hz 24.0" Monitor  (€305.67 @ Amazon Deutschland)
Total: €1160.53
Generated by PCPartPicker 2015-12-19 07:55 CET+0100
