Humming noise from my hdd
thezodiacmachine
i did a health check on it and is good. but it is making a humming sound and causing my case to vibrate. i suspect is cause i put the hdd on the top most slot which caused the side panel to vibrate as well
Its a common problem, get an anti vibration caddy, or modify the cage with rubber bands
i have the same issue :|
        Sample Text ( ͡° ͜ʖ ͡°)
make sure its tightly screwed to the case. also check if hdd screws are loose. do those, if still vibrates i suggest that you submerge it in oil and then put it back and then it probably wont work anymore so the vibrating is fixed
i mean, do that if the vibrating is bad/you dont want to listen to it
heres a video of the sound..
i checked it is tightly secured
Edited by Spotty
removed vid.me link
