So I'm looking to get one of those 4-10 port usb charging stations for my various devices. I know that current matters for charging tablets and larger devices, so what should i look for for under 15 bucks? This one looks alright http://www.ebay.com/itm/6-Port-USB-HUB-Desktop-Wall-Charger-Power-Charging-Cable-For-Smartphone-US-Plug-/231699067253?hash=item35f2573175:g:cF0AAOSwKIpWA9d1
https://linustechtips.com/topic/507519-usb-hub-charger/
http://www.amazon.com/Anker-Desktop-Charger-Technology-Smartphones/dp/B00DVH62J2/ref=sr_1_4?ie=UTF8&qid=1450397324&sr=8-4&keywords=usb+hub+charger
2.4A per port
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/507519-usb-hub-charger/#findComment-6772978
